Staining Ash... Any Ideas?... Any Comments?
Forum topic by TheGov posted 545 days ago 924 views 0 times favorited 4 replies Add to Favorites Watch
View TheGov's profile
TheGov
18 posts in 549 days
545 days ago
Hey gang
I’m building a buffet with a hutch, basically a liquor cabinet.
I’m constructing the project with 3/4 ash. I want to stain the ash a dark brown of cherry stain.
This is my first project with an instructor. It is also a 1 year anniversary present to my wife. I want to give it a magnificent finish. I have a columbian teak table with a dark brown, redish stain that i’d like to match with the buffet. I don’t want a glossy finish but i also don’t want the piece to be dull. Can any one help me with any ideas?
-- What can i say i'm just doing what i love.
View EdC's profile
EdC
458 posts in 736 days
545 days ago
Myself I would find a good finisher in your area and sub it out. Or youcheck under the forums go to woodworking skills and find the title Smart Tails Charles Neil started the topic, get in touch with him he can answer your questions. He is one of the best finishers there is on the web.
-- Ed - Milan, IN
View trifern's profile
trifern
7894 posts in 663 days
545 days ago
Do several tests on scraps that have been sanded the same as your hutch until you are satisfied. Satin poly has a nice in between sheen, not too glossy or dull. I have the best results with any finish by doing multiple thin coats as opposed to a couple of heavy ones. Ash usually takes stain well. I would not sand past 150 grit, otherwise the stain will be blotchy.
View motthunter's profile
motthunter
2079 posts in 695 days
545 days ago
test.. test.. test… I like to use sanding sealer first to even out the stain and avoid blotching. Gel Stains help too
-- making sawdust....
View bfd's profile
bfd
419 posts in 703 days
540 days ago
I personally prefer to use dye stains from transtint which are available at Rockler.com, woodcraft.com and veneersupplies.com (which has the best price). You get 2 oz of concetrated dye that you can mix with either distilled water or alcohol. The trick is to test on sample boards through the entire finish schedule that you will use on the actual project. I find that once you get the hang of working with dye stains and the steps that are involved you will find that the finish is simply beautiful. Since it is a dye vs. pigment the stain penetrates the wood very evenly. It looks a little muddy going on but once you seal it and then add a top coat it will look great! Also if you mix with water you have a stain that has very low voc but you have to pre-raise the grain.
-- Brian, Folsom, CA http://www.brianfullerdesigns.com
