Abranet product problem
Forum topic by jtriggs posted 02-15-2012 09:20 PM 1328 views 0 times favorited 6 replies Add to Favorites Watch
View jtriggs's profile
jtriggs
181 posts in 3840 days
02-15-2012 09:20 PM
I just invested in a couple 50 count packs of 100 and 220 grit Abranet. Was excited to try them after all the hoopla on the web but was disappointed that they would not stay on my Dewalt orbital sander hook and loop pad. They supposedly have the loop material on the back but they came loose after only a few minutes of sanding.
Do I have worn out hooks on my Dewalt? Or is there something I’m missing here?
Thanks for any help on this question.
Jon
-- Jon --Always remember, never live your life by a motto.
View doninvegas's profile
doninvegas
334 posts in 2931 days
#1 posted 02-15-2012 09:26 PM
Probably worn out hooks on the sander. How old is it? I use my ROS a lot and have to change out the pad about every 9 or 10 months or so.
-- "Courage is being scared to death -- but saddling up anyway."
View rkober's profile
rkober
137 posts in 2316 days
#2 posted 02-15-2012 09:46 PM
I had a similar experience with my old Ryobi sander. Normal pads were sticking fine but after throwing the Abranets off a few times the sander pad is wrecked. Just picked up some Abranet backing pads today and will try (which I probably should have used originally). However I have a bad feeling I’ll need to replace the sander pad (or sander). Otherwise the Abranet pads work great.
-- Ray - Spokane, WA - “Most people don’t recognize opportunity because it’s usually disguised as hard work.” - Unknown
View Sarit's profile
Sarit
549 posts in 3163 days
#3 posted 02-15-2012 09:50 PM
The open nature of the Abranet tends 1) reduce the amount of loop material available on the pad and 2) increase the wear of the ROS pad. They sell a Mirka 9955RP 5-Inch Pad Protector, mulit hole for vacuum sanding which is still cheaper then replacing the pad on my sander @ $50.
View Bobsboxes's profile
Bobsboxes
1367 posts in 2687 days
#4 posted 02-15-2012 10:13 PM
Sarit has it covered, without the pad protector you wreck your sanding pad. I also went thur this, I bought the Abranet discs at a large tool supply in person, none of the sales men said anything, i also wrecked my sander pad. I had asked a couple of the sales men what I needed, they both said just the discs.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View gfadvm's profile
gfadvm
14940 posts in 2713 days
#5 posted 02-16-2012 02:47 AM
Yep, Sarit and Bugz nailed it. You have to have their pad of you’ll have trouble. Having said that, I can honestly say that discovering Abranet has actually made sanding an enjoyable task. And I can’t wear the discs out! One of my best investments.
jtriggs
#6 posted 02-16-2012 06:28 AM
Thanks everyone. Look’s like I’m not done investing in new stuff yet.
I knew you good folks would give me the straight skinny. How did that phrase ever start, I wonder.
Jon
