Delta 50-760 Delta 1 1/2hp Dust Collector, Joliet IL
Forum topic by 4skinz80 posted 02-15-2012 06:14 PM 2051 views 0 times favorited 2 replies Add to Favorites Watch
View 4skinz80's profile
4skinz80
22 posts in 2468 days
02-15-2012 06:14 PM
Delta 1 1/2hp Dust Collector… Comes with a couple blast gates… A Expandable hose from rockler (expands from 3’ to about 16’) and The rockler dust right floor sweep System. $250 call email or text 815-6eight5-1746
I can deliver up to 300 miles for a fee based on how far away…
The 50-760 includes motor and blower, support frame, 1 Micron Filtration Bag with Sewn-In Bag Ring, (2) 6 mil plastic chip collection bags, (1) snap-in bag ring, (2) 4” intake ports, (4) swivel caster assemblies, cord and plug.
Standard 1 micron filtration bag keeps your shop safer and cleaner
Snap-in bag rings are faster, easier and eliminate the need for cam-over-lock style clamps
Powerful TEFC induction motor for long-lasting, smooth performance with protection from damaging dust
6 mil plastic chip collection bag shows you when the bag needs emptying
Sturdy steel base with four easy-gliding wheels for moving from machine to machine or for storing out of the way
Motor: 1-1/2 HP, 3,450 rpm, 120/240V (Wired 120V), 1 Phase, 60 Hz Max CFM: 1200 CFM
Max Static Pressure: 8 (inches of water) Impeller Diameter: 11.5”
Filter Bag Area: 20.5 sq ft, 1.9 sq m Standard Bag Filtration: 1 Micron
Chip Bag Area: 2.4 cu ft, 67 L Length: 35”
Width: 19” Height: 83”
Weight: 95 lbs
2 replies so far
4skinz80
#1 posted 02-21-2012 06:22 PM
ttt
4skinz80
#2 posted 02-27-2012 05:57 PM
sold
