G0490 Grizzly 8" Jointer, Joliet IL
Forum topic by 4skinz80 posted 02-15-2012 05:54 PM 1966 views 0 times favorited 3 replies Add to Favorites Watch
View 4skinz80's profile
4skinz80
22 posts in 2348 days
02-15-2012 05:54 PM
Grizzly 8” Jointer…. Barely Used… In Great shape… comes with two push blocks… $600 Can deliver up to 300 miles for a fee based on how far away… Call email or text 815-6eight5-1746
4skinz80@gmail.com
This 8” Jointer is sure to be popular among both professional and hobbyist woodworkers. The extra long 76 5/16” table and the extra long and extra tall fence will make sure your stock is cut accurately. The easy to reach pedestal mounted switch and lever controlled table elevation make this a joy to operate. Out foot pedal operated, built-in mobile base will allow you to keep this monster out of the way, yet easy to move when needed. We made the welded steel cabinet extra large for an incredibly stable platform. This machine will gobble up wood with ease and produce smooth, straight and flat stock all day long.
Specifications
Motor: 3 HP, 220V, single-phase, TEFC, 3450 RPM
Total table size: 8” x 76 5/16”
Infeed table size: 8” x 43 3/8”
Cutterhead knives: 4 HSS, 8” x 3/4” x 1/8”
Cutterhead speed: 5350 RPM
Cutterhead diameter: 3 3/16”
Max. depth of cut: 1/8”
Max. rabbeting depth: 1/2”
Cuts per minute: 21,400
Deluxe cast iron fence size: 35”L x 1 1/4”W x 5”H
Approximate shipping weight: 564 lbs.
Features
Shielded and lubricated bearings
Precision ground cast iron tables
Fully adjustable tables
Single V-belt drive
Easy access lever adjusted tables with height gauge
Heavy-duty center mounted fence with angle gauge
Built-in dust chute with 4” port
Powder coated paint
Table adjustment mechanism all components are interlocked for maximum precision
Pedestal mounted switch for convenience
Sturdy cabinet stand
3 replies so far
View wncguy's profile
wncguy
353 posts in 2186 days
#1 posted 02-15-2012 07:42 PM
4skinz80 – Based on the photo of coach D, guess you’re in Chicago area… If so, I’m beyond your travel limit.
-- Any man can be a father, but it takes someone special to be a Dad
4skinz80
#2 posted 02-15-2012 08:17 PM
sale pending
4skinz80
#3 posted 02-15-2012 10:48 PM
sold
