G0513 Grizzly Bandsaw, Joliet IL
Forum topic by 4skinz80 posted 02-15-2012 05:39 PM 2077 views 0 times favorited 1 reply Add to Favorites Watch
View 4skinz80's profile
4skinz80
22 posts in 2474 days
02-15-2012 05:39 PM
Saw is Barely Used… Brand New 1/2” 3-4 tpi variable tooth pitch design WoodSlicer Blade from Highland woodworking, Brand new urethane tires, comes with a push pad and a stone to grind the back of the blade. $600
I can deliver up to 300miles for a fee, it will be based on how far away. Call, Text, or Email… 815-6eight5-1746 or 4skinz80@gmail.com
For those that need a respectable cutting capacity at a respectable price, Grizzly is proud to offer this full-featured 17” Heavy-duty Bandsaw. The 2 HP motor powers through wood up to a maximum 12” cutting capacity and the 16-1/4” throat is plenty for most applications. Features like the deluxe fence, heavy-duty miter gauge, dual 4” dust ports, micro adjusting geared table and European style blade guides are usually found on machines costing much more. And, the ISO 9001 factory designation assures high quality standards
SPECIFICATIONS:
Motor: 2 HP, 110V/220V, single-phase,
TEFC capacitor start induction, 60 Hz,
prewired 220V
Amps: 20/10
RPM: 1725
Power transfer: Belt drive
Precision ground cast iron table
Table size: 17” x 17” x 1-1/2” thick
Table tilt: 10° left, 45° right
Floor to table height: 37-1/2”
Cutting capacity/throat: 16-1/4” left of blade
Maximum cutting height: 12”
Blade size: 131-1/2” long
Blade sizes available: 1/8” – 1” wide
2 blade speeds: 1700 & 3500 FPM
Wheels: fully balanced cast aluminum
with polyurethane tires
Wheel covers: pre-formed steel
Blade guides: Euro-style roller disc with
full enclosure protection
Bearings: sealed and permanently
lubricated
Overall size: 73” H x 32” W x 32” D
Approximate shipping weight: 342 lbs.
FEATURES:
Deluxe extruded aluminum fence
Miter gauge
Two 4” dust ports
Quick change blade release/tensioner
Blade tension indicator
Micro adjusting geared table
Height scale measurement
Blade tracking window
1 reply so far
4skinz80
#1 posted 02-15-2012 10:48 PM
sold
