Attention Pen Turners, repetitive cutting of brass tubes...
Forum topic by ShannonRogers posted 133 days ago 131 views 0 times favorited 5 replies Add to Favorites
View ShannonRogers's profile
ShannonRogers
244 posts in 272 days
133 days ago
Topic tags/keywords: pen turning
LJ’s,
I just purchased some replacement brass tubes for pens and they came in long lengths from the retailer. Since I know that I will be making a lot of this style of pen I am wondering if anyone has any ideas or built any jigs that allow for repetitive cuts safely in this small scale. The repeatability and safety are my biggest concerns since I want the finished pens to be identical and the scale is quite small and seems like an accident waiting to happen. Any thoughts, ideas, etc.
-- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog
View fredf's profile
fredf
188 posts in 194 days
133 days ago
what size tube, what length?? I assume square ends??
-- Fred, Springfield, Ma
View Mario's profile
Mario
714 posts in 536 days
133 days ago
HF has a small saw that does a good job on this. bolt it to a peice of plywood and make an adjustible stop system like the ones used on Miter saws. It works great. The saw is 25.00 and has a 2” blade.ITEM 42307-6VGA
This will save money in the long run as it is cheaper to but the tube stock in bulk.
-- Hope Never fails
View jeffthewoodwacker's profile
jeffthewoodwacker
193 posts in 289 days
133 days ago
I made a jig to use on my band saw to cut the brass tubes to length. Pretty simple to use. The jig is a sled with a rail to ride in the miter gauge slot. I use a stop to get consistent lengths for the various pens that I make.
-- Genius is immediate, but talent takes time.
ShannonRogers
133 days ago
Mario, I have seen this before. Penn State sells it for $55! They say they include jigs for 3 different size tubes. I cannot believe the price difference for the same tool!
ShannonRogers
132 days ago
So I put some more thought into this and so far I have have made well over 200 pens and this tube trimming issue only just now came up. Until the need arises more often I think a simple measure would suffice best. Here is what I came up with using some scrap plywood. I clamped the fixture to the miter gauge to set the distance to the band saw blade. The stops on either side of the tube are fixed using double sided tape so that I can adjust the width for different diameters in the future.
Bookmark And Share This Page
