Forum topic by TimberMan | posted 02-14-2012 09:03 PM | 1128 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: table leg shapping I am trying to figure out if I want to attempt to make this leg or not. My thought is that I would cut the pattern on the bandsaw and then tapper the leg. I will probably make a bit more tapered then drawn. Any recommendation on cutting a pattern like this 4 times per leg x 4 legs? |
7 replies so far
#1 posted 02-14-2012 09:17 PM |
it depends on the dimensions, but if the leg is not too thick the easiest and fastest approach might be to make a template out of masonite, cut to rough dimension on the bandsaw, and the true up with an edge router using the template to guide the ball bearing on the bit. Eh? As you say, you definitely will want to cut the pattern before tapering the legs. -- dave : vermont |
#2 posted 02-14-2012 09:21 PM |
Defenitly cut the pattern before tapering. I would say bandsaw the profile and clean it up -- {Current North Bennet street school student} |
#3 posted 02-14-2012 09:22 PM |
A couple of molding planes. Line them up and cut across 4 at once. |
#4 posted 02-14-2012 09:58 PM |
You could use a router with some round bits. You could use some molding planes if you have a good assortment of hollows and rounds. You could use some gouges, that would be pretty time consuming. You could also use rasps and sand it smooth once you have the shapes where you want them. Fastest way is definitely with a router. Good luck and have fun! -- Mike |
#5 posted 02-14-2012 10:24 PM |
Applied mouldings is one way to do it, but you can also rough to |
#6 posted 02-14-2012 10:27 PM |
What Loren says. I have made similar things with files and rasps. Cut it close and shape it with hand tools. |
#7 posted 02-14-2012 10:39 PM |
Thanks for the ideas. Unfortunately, I do not have many hand tools. I do have a few rasps though so that is certainly possible. WudnHevn – thanks for that creative idea. I will have to give that one some thought. Something tells me you had those drawings handy! If not then thanks for taking the time to draw them out. |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
