Do you put rubber pads on your cutting boards?
Forum topic by KenBry posted 02-14-2012 07:15 PM 14898 views 0 times favorited 15 replies Add to Favorites Watch
View KenBry's profile
KenBry
484 posts in 2416 days
02-14-2012 07:15 PM
Last 2 cutting boards I made (the only 2) I put rubber feet on them. I did it to help keep them out of liquids and keep them from sliding on the counter. Do any of you also do something similar?
The only sources I found for the rubber feet where the Big box stores.
I selected feet that have to get attached to the wood with screws as opposed to stick on style. I found that the stick on style on other things never stay, I wanted something more perminant.
-- Ken, USAF MSgt, Ret.
15 replies so far
View darinS's profile
darinS
709 posts in 2836 days
#1 posted 02-14-2012 07:19 PM
I haven’t added any feet to mine (only built one so far, have another planned). Don’t go by my say so though because mine came apart on me due to my own stupidity. Should have checked a few more things here before I did mine. There is something to be said for having flat surfaces to glue together.
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
View Brandon's profile
Brandon
4152 posts in 2920 days
#2 posted 02-14-2012 07:23 PM
I’ve used wooden “buttons,” you know, the kind you might cover screw holes with. They’ve worked pretty well, but still susceptible to sliding. I haven’t seen rubber feet that I’ve thought would work very well.
-- "hold fast to that which is good"
View ellen35's profile
ellen35
2734 posts in 3401 days
#3 posted 02-14-2012 07:26 PM
I use those little clear bumpers on my boards. I know they fall off after a while, but they do give some traction and they prevent scratching the counter or table. I get them wherever they are the cheapest. If they fall off before I have sold/given away a board, I’ll put a little CA glue down and re-stick it.
They seem to work fine.
View RONFINCH's profile
RONFINCH
143 posts in 2893 days
#4 posted 02-14-2012 07:48 PM
I use these, work very well.
View lew's profile
lew
12019 posts in 3724 days
#5 posted 02-14-2012 08:36 PM
These are best I’ve found. They are just soft enough and don’t slide.
http://www.leevalley.com/US/hardware/page.aspx?p=62154&cat=3,40993,41285&ap=1
KenBry
#6 posted 02-14-2012 09:34 PM
Ron, those look like what I got at Home Depot or Lowes. But Yea, those.
RONFINCH
#7 posted 02-14-2012 10:03 PM
Yup, Home Depot…...
View adaughhetee's profile
adaughhetee
104 posts in 2652 days
#8 posted 02-15-2012 12:37 AM
This is what I use they seem to be a softer than the other black ones. I’ve found them at HD and Ace hardware haven’t found them at lowe’s though.
http://www.acehardware.com/product/index.jsp?productId=1286055&kw=rubber+bumpers&origkw=rubber+bumpers&searchId=54801862794
View doninvegas's profile
doninvegas
334 posts in 2876 days
#9 posted 02-15-2012 09:09 PM
I use the clear ones I get from Lowe’s. I always put a dab of CA glue on them first and I haven’t had one come off, “YET”.
-- "Courage is being scared to death -- but saddling up anyway."
View rkober's profile
rkober
137 posts in 2261 days
#10 posted 02-15-2012 09:54 PM
I have thought about it but haven’t done it. I’ve seen recommendations to put a damp paper towel under the board while using to get some traction which I’ve done. What about about drilling a recess to place the pads into to resist shear force? For those who are gluing, do you glue before finishing?
-- Ray - Spokane, WA - “Most people don’t recognize opportunity because it’s usually disguised as hard work.” - Unknown
View Philzoel's profile
Philzoel
302 posts in 2312 days
#11 posted 02-15-2012 09:55 PM
I use the Home Depot ig. black ones. They are very stable for cutting. No slipping. Keep then 1” to 1 1/2 inch from edge so board will not flip up from edge pressure.
-- Phil Zoeller louisville, KY
View Sawkerf's profile
Sawkerf
1730 posts in 3037 days
#12 posted 02-15-2012 10:02 PM
My “cutting boards” are usually made from whatever scrap I have left over from diferent jobs thru the year and are given to customers as Xmas presents.
Since they aren’t really intended for cutting/chopping etc, I put rubber or plastic “feet” on them and call them serving boards.
View richgreer's profile
richgreer
4541 posts in 3043 days
#13 posted 02-16-2012 02:51 AM
Let me offer, what I think is, a very good idea. I’ve made several things recently with rubber “feet”. However, the “feet” are actually patches of rubber from an old bicycle inner tube. I cut patches that are about 1.5” x 3”. I attach them with Barge glue which works great in this application.
These patches of rubber do a great job of keeping things from sliding around on a countertop and they are only about 1/32” thick.
View Jonathan's profile
Jonathan
2608 posts in 3019 days
#14 posted 02-16-2012 03:42 AM
You can check my projects and blogs for the various feet Ive used. I wouldn’t personally build a board without feet. Not only do feet provide traction, they also allow the board to easily and thoroughly dry on the countertop after washing it. I believe this is especially important with end grain boards, as end-grain boards obviously wick more moisture when washed.
I only use feet that screw into the board for longevity. And I also make sure to swap out the screws that tend to come with the feet for stainless steel screws. I learned that one from experience. Yes, it costs a tiny bit more to but the SS screws, but to me, is worth it to prevent rusting issues and uphold my personal stringent build standards.
I have not yet gone the stick-on route, but if I did, I’d definitely add some CA glue, as others have mentioned.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View grenger's profile
grenger
199 posts in 3335 days
#15 posted 06-23-2013 01:04 PM
used the glue on type for a while but they tend to unglue.
i now used these
http://www.leevalley.com/US/hardware/page.aspx?p=40043&cat=3,40993,41285
they come in different sizes. They do not come off
-- Gerry (the beginner), Gatineau, QC, Canada
