How do you keep those darn nails from creeping up through a saddle?
Forum topic by AttnToDetail posted 02-14-2012 06:28 PM 4269 views 0 times favorited 10 replies Add to Favorites Watch
View AttnToDetail's profile
AttnToDetail
16 posts in 2436 days
02-14-2012 06:28 PM
Topic tags/keywords: saddle threshold nail
Looking for some good advice. I installed a long oak saddle (aka threshold) a few years back between my living room and kitchen, so it does see some high traffic. Every few months some of the nails holding it down creep up a little bit and snag your sock. Anyone have any good tricks for keeping these nails laid to bed???
-- You can't rush greatness.
10 replies so far
View Alan S's profile
Alan S
181 posts in 3316 days
#1 posted 02-14-2012 07:08 PM
I put in hardwood floors last year, but I’m not sure I did everything the way a professional would have. Two of my thresholds I nailed down because I plan to redo the connecting floor (bathroom tile) in the future. Another threshold I glued down with loctite PL construction adhesive. The glued down threshold hasn’t had a problem but the ones I nailed down definitely squeak. Maybe glue down your threshold if you are able.
Alan
View KenBry's profile
KenBry
484 posts in 2446 days
#2 posted 02-14-2012 07:20 PM
Yep, glued mine down too. Not sure if it’s right or wrong but it hasn’t budged in 3 years and no holes in my socks because of it.
It also sounds like you need to take a punch and drive those nails a tad deeper into the wood. Usually when I have something like you discribe, I predrill the wood then I sink the nail deeper into the item. Then I use filler to hide the hole. But I only do this method on moldings around the floors. Never tried it on a threshold but I think it would work.
-- Ken, USAF MSgt, Ret.
View Dallas's profile
Dallas
3599 posts in 2486 days
#3 posted 02-14-2012 07:37 PM
If you nailed with shiny nails you can expect them to give over time. They have nothing to keep them in. Ring Shank nails, double dipped galvanized or glue nails will work much better.
You could always try predrilling large holes and pilot holes then put coarse thread screws in then plug the holes with a dowel.
View crank49's profile
crank49
4030 posts in 2969 days
#4 posted 02-14-2012 07:42 PM
I drilled and countersunk mine and screwed them down with large brass screws. Rather than hide the screws I polished the heads before I put them in and sprayed with clear lacquer so they wouldn’t tarnish.
404 - Not Found
2544 posts in 2968 days
#5 posted 02-14-2012 08:52 PM
Square cut nails won’t pull out but wouldn’t be suitable for your oak door saddle. I think you may be better off using brass screws and plugging the holes.
View mtenterprises's profile
mtenterprises
933 posts in 2691 days
#6 posted 02-14-2012 09:51 PM
Drive your nails in at opposing angles, not streight in.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Grandpa's profile
Grandpa
3259 posts in 2674 days
#7 posted 02-14-2012 10:49 PM
If the floor is wood and the adhesive doesn’t work (try that first) then use trim screws and plug or patch the hole just like it was a nail. If the floor is concrete then use Tap-Con screws and plug with regular plugs.
View JohnnyM's profile
JohnnyM
39 posts in 2331 days
#8 posted 02-14-2012 10:54 PM
I’ve always used trim head screws on the thresholds I have installed with no issues over the years.
-- ~~ John . . . . . . . . . Against the Grain Woodworking & Design, LLC
View Jim Finn's profile
Jim Finn
2656 posts in 2920 days
#9 posted 02-15-2012 12:13 AM
Twist nails may work.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
AttnToDetail
#10 posted 02-16-2012 05:05 AM
Thanks for the ideas. I think I’m going to try the trim screws.
