Need some guidance on finishing a Teak table for a boat
Forum topic by eugene54 posted 467 days ago 675 views 0 times favorited 8 replies Add to Favorites Watch
View eugene54's profile
eugene54
8 posts in 808 days
467 days ago
Topic tags/keywords: teak marine table
I am working on a replacement teak table for a friend’s boat. It’s for an interior space so it won’t be directly exposed to the elements. I am not sure how to go about finishing it.
Can anyone recommend a finishing process? The aim is a durable surface with minimal maintenance needs.
8 replies so far
View Bill White's profile
Bill White
2609 posts in 2133 days
#1 posted 467 days ago
Teak? Oil and wax for me. Don’t even talk about polycrapithane.
Bill
-- bill@magraphics.us
View Earlextech's profile
Earlextech
601 posts in 863 days
#2 posted 466 days ago
Teak oil
-- Sam Hamory - The project is never finished until its "finished"!
View Greg The Cajun Box Sculptor's profile
3781 posts in 1481 days
#3 posted 466 days ago
I have a teak dresser I built in 1975. After being underwater for several weeks back in 2005 I sanded it and refinished it with a water based varnish. It is important to wipe it down with acetone prior to applying the finish so amy surface oils will be removed. six+ years later the finish looks excellent.
I would only use this water based finish on an inside piece.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
View CaptRandy's profile
CaptRandy
21 posts in 835 days
#4 posted 466 days ago
Clean well with sudsy ammonia brushing cross grain then rinse well with water. Let it dry then fininsh with Amazon Teak Oil.
View HoBoMoNK's profile
HoBoMoNK
1381 posts in 2300 days
#5 posted 466 days ago
On teak for outdoor usage, I use Waterlox Original Marine Finish or a good tung oil/phenolic resin spar varnish.
Note: So called “Teak Oil” is a meaningless and vague name. Some Teak Oil products contain only oils and others contain mostly solvents, a little oil and some resin. One product only contains a mixture of castor oil and mineral oil. There is no consistency among “Teak Oil” formulations.
Blessings,
Bro. Tenzin
-- 温故知新
View Clint Searl's profile
Clint Searl
851 posts in 534 days
#6 posted 461 days ago
Water based poly for floors. I like Varathane.
-- Clint Searl.............We deserve what we tolerate
Clint Searl
#7 posted 384 days ago
“Teak Oil” is snake oil. Use poly, either oil or waterborne. I prefer waterborne, though aI made a teak table, finished with oil poly, in 1974, that’s still going strong.
View Fuzzy's profile
Fuzzy
251 posts in 2161 days
#8 posted 384 days ago
TEAK and CYPRUS … I prefer PENOFIN … as it weathers and loses a little color, just reapply as desired.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
