how does this attach to the wall..?
Forum topic by joshtank posted 02-13-2012 03:13 PM 1136 views 0 times favorited 9 replies Add to Favorites Watch
View joshtank's profile
joshtank
224 posts in 2998 days
02-13-2012 03:13 PM
9 replies so far
View ChrisK's profile
ChrisK
1972 posts in 3106 days
#1 posted 02-13-2012 03:18 PM
Looks like a block is lagged to a 2×4 and then the mount slips over the block and is screwed in from the top.
-- Chris K
View crank49's profile
crank49
4032 posts in 2996 days
#2 posted 02-13-2012 03:29 PM
Looks like you could hang it off the price; it’s high enough.
View joedw00's profile
joedw00
21 posts in 3538 days
#3 posted 02-13-2012 03:53 PM
Sure is a lot for a couple pieces of Walnut. Wonder what they mean by “The Bike rack mounts to a single stud utilizing a simple lumber mounting bracket that is incredibly strong. “
-- Had we known Grankids were this much fun we would have had them first.
View junebug's profile
junebug
101 posts in 2429 days
#4 posted 02-13-2012 04:36 PM
it looks just like a single lag bolt through a slot in a wood plate.
using a bit of photoshop, you can see it here as well.
I’m assuming its a slot because the bolt is in a different location in each picture. It would allow you to center the bike on the wall regardless of the stud location. In the other pictures, you can see the 3 screws they use to secure the bike rack to the wall plate
joshtank
#5 posted 02-13-2012 06:09 PM
crank and joe. yes indeed. a few friends of mine thought it was neat and were asking if i could build one. for $100 i’mm make four of them. seriously. big pricing.
thanks for the photoshop closeups junebug!
-- Josh - Jacksonville, FL - https://www.youtube.com/channel/UC6eXmOxkM10zI0d-njOHeRQ
View startreking's profile
startreking
36 posts in 2324 days
#6 posted 02-13-2012 06:58 PM
That better be made out of solid gold with cheap veneer for that price.
View hhhopks's profile
hhhopks
651 posts in 2402 days
#7 posted 02-13-2012 07:34 PM
Keep in mind that these bike don’t weight much. You should able to pich up one of those bike with one hand. Two hands to mount it on to the block.
So, it should take much to mount the block.
-- I'll be a woodworker when I grow up. HHHOPKS
View drfixit's profile
drfixit
318 posts in 3169 days
#8 posted 02-13-2012 11:09 PM
If you look closely at their photo, you can see 3 holes in the top of the shelf, where the shelf is screwed down to the block that would be bolted to the wall.
-- I GIVE UP!!!! I've cut this @!&*!% board 3 times.... its still too short!
joedw00
#9 posted 02-14-2012 03:33 AM
Looks like you screw the back to a stud then you screw the hanger to it. Not too complicated. I guess I missed drfixit last post. Must have had a senior moment.
