Smokin' the pine with a circular saw
Forum topic by Brett posted 461 days ago 962 views 0 times favorited 8 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 849 days
461 days ago
When I cross-cut a bunch of 2×12 southern yellow pine from the home center with my circular saw today, I was getting a lot of grey smoke, even with a 16-tooth blade cutting only 7/8” deep. The blade is one of the originals that came with the Skil-saw, but it hasn’t received a lot of use. Afterwards, I ripped the boards on my table saw and had no problems—no smoke, no nothing, just clean cuts. Is my circular saw blade just dull, or is the saw just too underpowered for cross-cutting a resinous wood like pine?
-- More tools, fewer machines.
8 replies so far
View Viking's profile
Viking
858 posts in 1361 days
#1 posted 461 days ago
Brett;
For some reason, most manufacturers are pleased to sell great tools with crappy blades. I suspect if you go get a good blade your cross cutting problem will be solved. I also use a 12” rafter square to CC 2x material to prevent binding.
Good luck.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Bill1225's profile
Bill1225
117 posts in 566 days
#2 posted 461 days ago
get a marathon blade 24t for rough cuts and you will good to go for a long while. (non-pro use) i use them on a daily basis when framing they are the best bang for the buck 8.99 each 19.99 3 pack
View madts's profile
madts
656 posts in 506 days
#3 posted 461 days ago
Sounds to me that you have some dull blades on the hand held saw. But, I hate to say this, could the blades be on backwards. Been there done that.
-- Thor and Odin are the greatest of Gods.
View AtomJack's profile
AtomJack
1279 posts in 1275 days
#4 posted 461 days ago
Are you using some kind of guide? If you get a little wobbly cutting across, you can get a fair amount of binding and the resultant smoke.
View bondogaposis's profile
bondogaposis
1237 posts in 517 days
#5 posted 461 days ago
Most saws come w/ throw away blades in the saw. My guess is the blade is crap.
-- Bondo Gaposis
Viking
#6 posted 461 days ago
Hey Bondo;
Not “most”, seems like “all “circular, table, band, saws come with cheap blades. They could ship them with no blades and take a few dollars off the price, at least in my experience.
Brett
#7 posted 461 days ago
No guide, just free-handing. But even when I cut slowly, I got smoke if I was anywhere near a knot. The blade worked fine a year ago when I was cutting douglas fir, but that’s a different wood entirely.
Bill1225
#8 posted 461 days ago
one other thing could be the yellow pine’s resin is clogging your gullets which can happen with any blade. a technique i use is lift the rear of the saw repeatedly while you are cutting almost like munching threw the board just be careful not to lift to high or your guard will swing in. If you are not comfortable with your saw don’t do this though
