Grizzly G1026 3HP Shaper
Forum topic by Quanter50 posted 461 days ago 1665 views 0 times favorited 13 replies Add to Favorites Watch
View Quanter50's profile
Quanter50
55 posts in 462 days
461 days ago
Picked up a well used Grizzly 3 HP shaper and stripped it down and repainted it. Both the power switch box and the reversing switch box were smashed. Reversing switch wires were jumped and the machine only ran in one direction when I got it. The wires on the motor cover box look like they were switched around. In that box on the motor there are 2 gray wires, 1 red, 1 yellow, 1 white, and 1 black. Does any one have an older G1026 that the could take a shot of the wiring configuration on the motor box. It would be nice to have a picture of the reversing switch too. Thanks for any help you could give me.
13 replies so far
View festeringsplinter's profile
festeringsplinter
10 posts in 529 days
#1 posted 461 days ago
If you go to the Grizzly website you can put in the model number in a search box ay the top of the page. Then when it pull up the machine you should be able to find a link to get to the manuals, the wiring diagrams will be in there. I had to do this as well when I picked up and old 1023 TS and a 16” dual drum sander.
Most parts are still available for the older machines as well!!
Good luck!!
Quanter50
#2 posted 461 days ago
I tried that. I think the diagram that they show is for the newer shapers. My shaper is from 1990. The wires are different from what I can tell. They just show a black, grey, and red coming out of the motor. Mine has 2 grays, 1 red, 1 yellow, 1 white and 1 black. Someone must have one of these older machines.
View lewis62's profile
lewis62
73 posts in 804 days
#3 posted 461 days ago
He got it. its all there.
Quanter50
#4 posted 461 days ago
I got nothing! What’s all there?
lewis62
#5 posted 461 days ago
Then I would try calling grizzly if they have your manual. Maybe might be able to email you with it, or send you a copy, have had good service from them, sorry do not have shaper.
sorry was typing and the other post came up and was the same as i was going to say.
If grizzly cant find one can you take pics of yours and try to work out wiring to the newer one they have.
Quanter50
#6 posted 461 days ago
Yeah…....I think I’ll try calling Grizzly tomorrow. I have had good luck with my other Grizzly machines and using Grizzly tech support. I’ll let you know how I make out. Thanks
Quanter50
#7 posted 460 days ago
Called Grizzly tech and talked with him. Said he would look for an old schematic and email me. Nothing. Emailed and asked again…..........nothing….
Quanter50
#8 posted 459 days ago
OK….....I figured out the wiring. Hooked everything up and turned shaper on. Ran good forward, but when I put it in reverse it ran with an accompanied hum for a while, then blew the breaker. Motor smelled burned. Ordered a new motor from grizzly. Problem solved!!
View RONFINCH's profile
RONFINCH
142 posts in 1090 days
#9 posted 459 days ago
Well, it shows you how little I know, had no idea shapers run in reverse, or the need for it to…......
Quanter50
#10 posted 459 days ago
Here’s before and after shots of my refinishing the Grizzly 3 HP Shaper
View jdon88's profile
jdon88
17 posts in 818 days
#11 posted 459 days ago
Great job. What kind of paint did you use? I’m going to paint my Grizzly jointer some day, it had the same color as yours in the before picture. I’ve been looking for the same color you used, looks like the newer Grizzlies. What about the nameplate/logo, is that new or did the old one clean up?
View Scot's profile
Scot
344 posts in 1562 days
#12 posted 459 days ago
Looks great
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
Quanter50
#13 posted 458 days ago
Grizzly sells paint in rattlecans. I used Rustoleum hammered green in the rattlecan. Comes out real nice! The name plate cleaned up with acetone and lots of elbow grease. Thanks
