Delta Band Saw Model 28-190
Forum topic by quilter posted 02-12-2012 11:17 PM 2726 views 0 times favorited 2 replies Add to Favorites Watch
View quilter's profile
quilter
3 posts in 2417 days
02-12-2012 11:17 PM
I am trying to remove a old bearing from the shaft. I have purchased the new bearings. How do you remove the old bearings and install the new ones. There must be some trick to removing the old bearing. Thanks. Ron
-- Ron
2 replies so far
View ben10's profile
ben10
42 posts in 2510 days
#1 posted 02-13-2012 02:10 AM
you’ll probably need a bearing puller to remove the old bearing. To install the new ones, get a piece of pipe that will fit over your shaft and tap on the new bearing with the pipe and hammer. Make sure you have a square end on the pipe.
-- Ben
quilter
#2 posted 02-13-2012 03:27 AM
Thanks Ben. I finally tried something similar and it worked well. Ron
-- Ron
