Staining Poplar
Forum topic by CraigMoore posted 467 days ago 7211 views 1 time favorited 29 replies Add to Favorites Watch
View CraigMoore's profile
CraigMoore
2 posts in 863 days
467 days ago
I have always heard you can’t stain poplar, so I have never tried. Well, my daughter ask me to make her six shelves for her boyfriends sons. I made them out of plywood & used poplar to cover the plywood edges cause she told me in the beginning they wanted them painted. Now she says they want them stained. I thought I read somewhere you can stain poplar but I dont remember where I read it. Any thoughts??
29 replies so far
View waho6o9's profile
waho6o9
2922 posts in 748 days
#1 posted 467 days ago
Sanding sealer first to prevent blotching. Test on scrap first. Good luck.
View Todd23's profile
Todd23
1007 posts in 676 days
#2 posted 467 days ago
Sanding sealer or wood conditioner is key to limit blotching. You CAN stain it, but know the greenish grain turns brown with age and will get quite dark. Also, poplar seems to “raise the grain” quite easily, and I always had to use a fine sanding sponge between stain or poly coats.
I DO like working poplar though. It’s a nice wood.
-- Todd http://www.PictureTrail.com/gid6255915
View Joe Lyddon's profile
Joe Lyddon
6396 posts in 2223 days
#3 posted 467 days ago
I stain Poplar all the time!
Works good for me!
I always use a rag and wipe it on… if one area gets darker than another, I merely wipe a little more in the lighter spots & it evens out… no biggy…
My favorite is Trans-Tints… work great!
View tenontim's profile
tenontim
2129 posts in 1915 days
#4 posted 467 days ago
Use aniline dyes, it works better. Arti sold by Highland woodworking or W.D. Lockwood sold by Tools for working wood are the best. Water based dyes are the most color fast, but you will have to wet down the wood and sand a couple of times, to take care of the grain raising.
-- Tim-- http://www.tmuli.com
View bench_dogg's profile
bench_dogg
63 posts in 1308 days
#5 posted 466 days ago
+1 to what tenontim said.
Test it out on a piece of scrap first. Once you apply the water based dye it will look terrible until you top coat it, don’t panic here.
View AmandasHusband's profile
AmandasHusband
58 posts in 864 days
#6 posted 466 days ago
On one of the Woodsmith Shop shows I remember them staining poplar w/ a dark gel stain and saying it looked like walnut. I thought it looked good. But not just like walnut like they said.
If you’re not interested in aniline dyes, you could try Charles Neils blotch control stuff. I saw his video on it about a year ago. Looks like it’s pretty good. The Wood Whisperer said something about it in a video or blog of his.
https://charlesneilwoodworking.3dcartstores.com/Charles-Neils-Pre-Color-Conditioner--Blotch-Control_p_47.html
Then, you can let me know how it works as I’m pretty sure I’m going to try it on this “rustic” pine table I just started yesterday for my 2nd favorite mother in law.
-- In this world there's two kinds of people my friend. Those with loaded guns and those who dig. You dig.
Joe Lyddon
#7 posted 466 days ago
I’m glad I watched Chas. Neil’s video… It clarified a lot!
Looks like he has finally developed a REAL solution to the Blotching problem once & for all!
I will have to get a can of that stuff and experience it for myself…
Thank you.
tenontim
#8 posted 466 days ago
Clear shellac works great for blotch control. Put it on with a brush or wipe it, let dry, then sand. Use the dye color of your choice.
View ben10's profile
ben10
41 posts in 560 days
#9 posted 466 days ago
I built bunk beds for my sons out of poplar. I had to stain it to match the store bought dressers…a very dark brown. I used Trans Tint dye stain and water. Worked a couple of coats into the wood, then put a coat of oil based stain on top. Finished it up with 3 coats of poly. It turned out perfect! There was some blotching but it disappeared when the poly went on.
-- Ben
Joe Lyddon
#10 posted 466 days ago
ben10: I like to do the same thing… except, I like to go with shellac instead of the poly… a beautiful combination.
View Howie's profile
Howie
2449 posts in 1094 days
#11 posted 466 days ago
Look at my projects. Several of them are stained poplar. Use a blotch control and don’t over sand(220 max)
-- Don't rollerskate in a buffalo herd
Joe Lyddon
#12 posted 466 days ago
You can make Poplar look like just about anything on the dark woods…
Joe Lyddon
#13 posted 466 days ago
“It will get dark but it will never look like those woods.”
Of course… you can’t change the grain… BUT, from a short distance, one can make Poplar appear to be many of the dark woods… Somebody else said that a long time ago… I’m just repeating them… LOL
That is why Poplar is so popular! LOL
View SnowyRiver's profile
SnowyRiver
45924 posts in 1651 days
#14 posted 466 days ago
I have stained poplar without any problems. I always look for clear poplar though for the project. I dont use poplar that is green. In my gallery I have a dove tail jig stand that I made which is stained poplar.
-- Wayne - Plymouth MN
View Jeremy Greiner's profile
Jeremy Greiner
510 posts in 943 days
#15 posted 466 days ago
I have used gel stain on poplar before and other than some blotching (I didn’t use sealer beforehand because I didn’t know what I was doing) it came out just fine.
This is the bench I made, all the “dark wood” is stained poplar
http://lumberjocks.com/projects/46958
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
showing 1 through 15 of 29 replies
