Help! Poly doesn't want a crack 'er scratch.
Forum topic by rmoore posted 02-12-2012 12:51 AM 1481 views 0 times favorited 18 replies Add to Favorites Watch
View rmoore's profile
rmoore
325 posts in 2813 days
02-12-2012 12:51 AM
Topic tags/keywords: polyurethane finishing
I’m refinishing a kitchen table. I have applied stain and am applying poly ( MinWax ). In a few spots it doesn’t want to absorb. These spots are in a seam or a scratch that didn’t get sanded out. Is it because of dirt of some sort? I have 4 coats on so far. I thought at first it was just soaking in and would eventually cover, but it isn’t. What do I need to do to get it to cover? I Just hope I don’t have to scrape it all off and start over! Hope these pictures help.
-- The more I learn, the more I realize I don't know. Ron, Crossville Tn
18 replies so far
View chrisstef's profile
chrisstef
17721 posts in 3184 days
#1 posted 02-12-2012 12:53 AM
Are you thinning the poly or is it full strength? Ive had issues using wipe on and it taking a ton of coats on reclaimed wood to absorb. I say stick with it ….
rmoore
#2 posted 02-12-2012 12:56 AM
I’m using it full strength.
chrisstef
#3 posted 02-12-2012 01:02 AM
hmmm … kinda puzzling. Theres gotta be somethin goin on there. Are you scuffing between coats? Maybe id drop down and hit the whole table with 220 to see if you can get something to bite. Just my thoughts.
rmoore
#4 posted 02-12-2012 01:25 AM
I did scuff between the first 2 coats. After the 3rd I scuffed the trouble spots and tried again with no luck.
chrisstef
#5 posted 02-12-2012 01:51 PM
giving this thread a little sunday mornin bump, there’s gotta be an answer out there.
View wdkits1's profile
wdkits1
215 posts in 3531 days
#6 posted 02-12-2012 02:48 PM
I have run into this same problem when refinishing table tops and discovered that old wax build-up is the culprit . In order to solve the problem you need to make sure that ALL of the old wax and finish is sanded off to bare wood. You will know that you got it all when the stain is absorbed equally in these spots. Stain and poly will not bond to wax.
-- Mike --http://www.custommade.com/by/mikemathieu/
View CharlesNeil's profile
CharlesNeil
2454 posts in 4048 days
#7 posted 02-12-2012 03:46 PM
the number of issues that can cause this is unreal , contamination in the seam, or the seam is slightly open , which will cause most finishes to repel from a sharp edge, finishes flow, and sharp edges dont allow them to flow over and into, lets fix it,>>>> once the coat is dry, use some Nahptha to clean the seem good , then if you have some, take a little shellac and using an artist brush apply some shellac in the seam, it will seal any contamination off, including wax, HOWEVER if the poly is oil base, be careful an uncured oil poly can be “lifted” by the shellac, shellac is a sure cure all, BUT BUT BUT, before doing that, simply put some poly in the seam, ( dry surface around it ), a small brush, or whatever, wet the seam , then using a clean finger, ( yes finger) simply wipe the poly ,working it around to force it into the seam, let dry , scuff sand and if needed do it again, to get the seam back to flush and rock and roll,
View Bertha's profile
Bertha
13551 posts in 2871 days
#8 posted 02-12-2012 04:12 PM
^there we go! I’m just happy when any solution involves shellac:)
rmoore
#9 posted 02-12-2012 07:54 PM
Thanks to all for the suggestions. Charles, I will try what you said.
chrisstef
#10 posted 02-12-2012 11:45 PM
Love it …. mmm nothin better than the smell of shellac in the morning.
View Dave's profile
Dave
11429 posts in 3018 days
#11 posted 02-13-2012 03:44 AM
Its probably silicon. Almost nothing will stick to it. Charles solution is the best route.
rmoore
#12 posted 02-13-2012 04:11 PM
Charles, I don’t have any naphtha right now. Will regular paint thinner or mineral spirits work?
117283 posts in 3755 days
#13 posted 02-13-2012 04:15 PM
A little lighter fluid will work.
rmoore
#14 posted 02-13-2012 04:19 PM
Thanks, Jim. Look like I need to get off here and go try it out.
CharlesNeil
#15 posted 02-14-2012 12:49 PM
yep Jim is correct, charcoal lighter fluid is nahptha , read the back
