| Forum topic by pashley | posted 547 days ago | 428 views | 0 times favorited | 15 replies | ![]() |
547 days ago |
Topic tags/keywords: joint In searching for the ultimate strong joint (and let’s face it, who isn’t?), a little idea popped into my little head. Perhaps you make a box or dovetail joint – pretty strong. As we all know, gluing it then welding it is not an option – I’ve tried a hundred times, and it never pans out. So here’s another idea: Put the joint together per usual , letting the glue dry. Drill a small caliber hole down thru all the fingers of the joint, then pin the joint with a dowel, which is glued in. Of course, the problem would be a joint too small to drill, and being able to bore a hole perfectly thru all fingers. Please send feel free to send me lavish monetary donations; I know this idea is going to change your woodworking world. I also like pretty flowers :) |
547 days ago |
Overkill! :^) -- Eric at http://adventuresinwoodworking.com |
547 days ago |
I seem to remember an article (I think FWW) where they tested MT joints to failure and they found that a pinned MT joint failed earlier than ones that were not pinned. I’ll try and find the article for your reference. -- ...it's rennovation time!!! |
547 days ago |
Two of the biggest factors I think determine the stongest joint depends on a couple of factors. The application and the amount of stock removal. I guess it just really all depends. I also seem to remember FWW getting a lot of responses on that article as well. Go figure as I think joinery in woodworking can be like talking about politics or religion, lol RJ |
547 days ago |
And if you’ve never seen the YouTube video that shows joint testing, it’s pretty awesome. -- Eric at http://adventuresinwoodworking.com |
547 days ago |
Here is a link to that video that is very interesting. -- Kyle Shipp, http://battleshipp.blogspot.com |
547 days ago |
Thanks, very cool |
547 days ago |
547 days ago |
That’s a very nice lil box!! I like that joint… nice touch! Thank you. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
547 days ago |
Yeah, like that! Nice little project there…. |
547 days ago |
Hey now that looks familier:) Yeah what Blake mentioned. Not very creative of me but it’s functional Below is a pic of a toy chest I built with different size dovetails. Probably not as strong but much more pleasant on the eye. The whole thought of balancing stock removal in a joint regardless of what type was mentioned to me in class I took with Graham Blackburn:) Kinda made sense so.. |
544 days ago |
RJ, When it comes to dovetails, it turns out that skinny pins (or unbalanced) is stronger than same size pins and tails. This was tested by Finewoodworking people in the same article mentioned by another LJ. I only use skinny pins, even for case work, and they are incredibly strong if you do them right. This is probably one of the biggest misconceptions about dovetails out there (Frank Klaus is of your opinion but I tend to trust scientific measurements more). Patrick, I think the dovetail joint FWW people tested failed at about 2000lb or force (3” joined with 3” in 3/4 material, maple). Now, if I would have to put my car on the joint I would consider strengthening it but I usually do not. Also, FWW measured the effect of a dowel through a mortise and tenon and the joint weakened (as mentioned in another post). That probably indicates that the dovetail or finger joint would weaken as well. -- -- Alin Dobra, Gainesville, Florida |
544 days ago |
I agree with RJones in the politics/religion aspect of this topic. I build Craftsman furniture and I know I can build 4 tables that you could park a Peterbuilt on if you wanted to. If you watch the video provided, yes, the MT joints fail, but the strength in the piece is not in that joint but rather the size of the leg, thickness of the top, and support of the top. The joint failure would be in a stretcher, which would never be subject to such a force. Even if it were, how much over a thousand pounds a square inch do you need to shoot for? Especially in a small box? bbqKing -- bbqKing, Lawrenceville |
543 days ago |
i dont see why you would need such a joint a simple dovetail should be good enough |
543 days ago |
i agree with alin, the skinny pins and larger tails are stronger than equal pins and tails. and kshipp i just watched that joint strength video and it is very interesting. |
542 days ago |
Alin, RJ |
| Forum | Topics |
Woodworking Skill Share
2916 |
3942 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2386 |
LumberJocks.com Site Feedback
524 |
