Quick Release Front Vise Installation
Forum topic by DonJ posted 464 days ago 866 views 0 times favorited 0 replies Add to Favorites Watch
View DonJ's profile
DonJ
198 posts in 1694 days
464 days ago
I purchased a quick release front vise from Peachtree that is similar to the Woodcraft one with a model #17A11. I’ve read the Woodcraft install instructions and ‘think’ I have it almost figured out. It says to be very careful when taking off the quick release nut, as it has to be repositioned perfectly. For anyone that has installed this type of vise, do you have some lessons learned for me or maybe a more descriptive way to explane its installation? In addition, any pictures would help.
I have the vise installed underneath the solid benchtop (2 1/2” thick), with the vise plate flush to the table side. I’m going to install a 4/4 piece of oak around the edge, which will be about 5 – 6” wide, and that will require that I drill the three holes to match up with the screw and two guide rods. As noted above, when I take the the vise apart, how did you mark the quick release nut so as to properly re-install it? Also, how far below the screw and guide rods would you recommend the edge facing (and vice face) be installed? Thanks for any help.
-- Don, San Antonio, TX
0 replies so far
