Modifying Dust Collection System
Forum topic by Big Ben posted 469 days ago 1139 views 0 times favorited 12 replies Add to Favorites Watch
View Big Ben's profile
Big Ben
69 posts in 1062 days
469 days ago
Topic tags/keywords: dust collection
I am looking to improve my dust collection, right now I have a HF 2HP DC. I like the unit but I hate changing the bag and in my 9’ x 11’ shop it takes up valuable floor space. Here is my solution:
I would like to modify the system by mounting the DC motor to the wall and connecting it to a Spun Bond Cartridge Filter (http://www.oneida-air.com/inventoryD.asp?item_no=FCS186200&CatId={4E3492E2-FDA2-470D-A725-CFD615650270}) and use a trash can with a Thien separator lid. I would be a able to store the trash can outside when not using the DC freeing up space. Has anyone done anything similar to this and do you think it would work?
12 replies so far
View Manitario's profile
Manitario
1862 posts in 1055 days
#1 posted 469 days ago
My suggestion would be to take a look at Wynn Environmental filters; you’ll save some $$$ compared to Oneida.
-- Rob, Sault Ste. Marie, Ontario
Big Ben
#2 posted 469 days ago
I should have said that I already the filter, it was a $75 CL find
View Gene Howe's profile
Gene Howe
3199 posts in 1600 days
#3 posted 469 days ago
Ben,
Can you vent it through the wall to the outside?
Big Ben
#4 posted 469 days ago
No I in townhouse
View MSD's profile
MSD
17 posts in 1012 days
#5 posted 469 days ago
Hey Big Ben,
I don’t see why you couldn’t do something like this http://lumberjocks.com/projects/29578 and just mount to the wall instead of a mobile base.
-- If it's true that we are here to help others, then what exactly are the others here for?
Big Ben
#6 posted 464 days ago
I have found two examples that are similar to what I want to build and both guys, seem happy with their systems.
http://lumberjocks.com/projects/60974
http://lumberjocks.com/Lance09/blog/26628
Big Ben
#7 posted 464 days ago
View kizerpea's profile
kizerpea
587 posts in 539 days
#8 posted 463 days ago
Woodmagazine….dust defying cyclone…i buy the plans an built my own.in my projects….others have done the same….after all…we are not just woodpeckers. we are creaters of things.
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View Martyroc's profile
Martyroc
2708 posts in 478 days
#9 posted 463 days ago
Hi Ben,
I have to agree with kizerpea, my shop is 20×20, actually 18×19 but the other measurement sounds better. I am currently building my own cyclone DC system, reason is, one because I think I can, two because I have a space carved out for it, three the cost of what I want would have my wife divorce me, four I have a ton of scrap and pallet wood and wanted to use it up, and finally because someone told me I couldn’t do it.
I don’t think it needs to be as huge as some of them out there, hell mine gets larger every day, just what you think you need is what you design and build. If you want to see what I am constructing have a look I posted click here
-- Martin ....always count the number of fingers you have before, and after using the saw.
View MrRon's profile
MrRon
1575 posts in 1415 days
#10 posted 460 days ago
That 2hp DC is pretty noisy. Attaching it to the wall may transmit noise to other residents. I think a 2hp DC is too much for such a small space. A small shop vac may be enough for your needs.
Big Ben
#11 posted 452 days ago
Here is a quick video of the completed system. I am happy with it, but may make a thien baffle at some point.
Does anyone know if putting a baffle on a box instead round drum or can would kill CFMs being pulled? It would save me a ton a space.
View piloon's profile
piloon
9 posts in 453 days
#12 posted 452 days ago
One trick that I found is to use old carpeting on adjacent walls, surfaces etc as it absorbs sound real good.
Wrap your drum with old carpeting as well (maybe glue some on), that’ll get rid of the tinny vibrations.
Just don’t wrap the motor as it will tend to overheat.
