What type of GLUE would this be?
Forum topic by longgone posted 02-10-2012 06:39 PM 1261 views 0 times favorited 8 replies Add to Favorites Watch
View longgone's profile
longgone
5688 posts in 3512 days
02-10-2012 06:39 PM
I sometimes use adhesive velvet lining for lining the bottom of my boxes. Sometimes I use leather instead and have used contact cement to glue the leather to the wood bottom. Contact cement requires applying it to both surfaces.
The adhesive backed felt I use has the adhesive on only one surface and has a peel-off paper backing. This is much easier but I would like to use this type of glue on the leather instead of contact cement.
Does anyone know what type of glue this might be?
The people at the hardware store, Lowes and myself included don’t have a clue.
Thanks!
8 replies so far
View Danpaddles's profile
Danpaddles
573 posts in 2515 days
#1 posted 02-10-2012 06:50 PM
I think it is not a glue, but a double sticky tape. Like carpet tape, but much thinner. It would be very hard to handle outside of a manufacturing environment. (and quite possibly a handful IN a manufacturing environment!!)
-- Dan V. in Indy
View Dallas's profile
Dallas
3599 posts in 2691 days
#2 posted 02-10-2012 06:51 PM
How about 3M’s Double Linered Adhesive Transfer Tape 7955MP.
Here
View cloakie1's profile
cloakie1
204 posts in 2758 days
#3 posted 02-10-2012 07:23 PM
i think it is like a double sided tape as well…when i was playing table tennis i could buy a sheet of double sided sticky for replacing the rubbers on my bat….i would think the same stuff would be ideal for what you want as well…can’t remember what it was called tho
-- just get stuck in and have a go!!!
View LittlePaw's profile
LittlePaw
1571 posts in 3282 days
#4 posted 02-10-2012 09:28 PM
Sorry, I don’t know, but I’ll be watching this to learn more, Greg. Thanx
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View Roger's profile
Roger
20952 posts in 3008 days
#5 posted 02-11-2012 01:28 AM
yup, what Paul said. I do know that whatever it is, it sure is sticky
View Tootles's profile
Tootles
808 posts in 2705 days
#6 posted 02-12-2012 12:27 PM
Some contact glues can be applied to only one surface. The catch is that you then need to apply pressure for a period of time, which you needn’t do if you apply that same glue to both surfaces and allow to dry before making contact.
-- I may have lost my marbles, but I still have my love of woodworking
cloakie1
#7 posted 02-13-2012 08:47 AM
i have just remembered about another product…can’t remember the name but it came in an aerolsol can and you just sprayed it on left it still it tacked off and then rolled you fabric into place….probably getit from an upholster i think
View woodluc's profile
woodluc
11 posts in 2533 days
#8 posted 02-13-2012 10:43 AM
Id say that it would be doubled sided tape also, but i have never seen it sold in anything wider than 6-30mm wide rolls. Maybe you can get wide rolls from a wholesalers.
I think that the stuff in the aerosol can is also a contact adhesive.
-- http://timberfurnitureplans.com/
