best clear finish for trim work?
Forum topic by RinnyTin posted 02-09-2012 08:24 PM 6802 views 0 times favorited 9 replies Add to Favorites Watch
View RinnyTin's profile
RinnyTin
39 posts in 2730 days
02-09-2012 08:24 PM
Finishing off the 3rd floor as playroom/guest bedroom, wife wanted the trim painted white, but I hate painting and love wood grain so we’ve compromised on a clear finish on pine moldings. I’m partial to Arm-R_Seal but don’t have a ton of experience so would welcome any input from you guys. Thanks!
9 replies so far
View Mainiac Matt 's profile
Mainiac Matt
8491 posts in 2500 days
#1 posted 02-09-2012 08:48 PM
I used poly-acrilic (water based poly… blue can…. I think Minwax makes it) on our pine trim when I built our house.
cut to length
sanded with 220 on belt sander
sealer
pecan stain
poly-acrlic
touch sand with 220 emery
poly-acrlic
poly-acrlic
installed with pneamatic finish nailer
looks great
took forever, even though the poly-acrlic dries really fast
when we built the addition I learned my lesson and used pre-primed tounge and finger joined trim and painted it.
-- I yam what I yam and that's all what I yam
RinnyTin
#2 posted 02-09-2012 09:07 PM
@ssnvet that sounds way too labor intensive for an attic rumpus room, I’m thinking more along the lines of 2 coats of varnish and done! Maybe I’m too optimistic…
View Loren's profile
10477 posts in 3819 days
#3 posted 02-09-2012 09:30 PM
I would use shellac if the floor is not to be mopped. Shellac
goes on quick and easy, looks great, is non-toxic. It can get
damaged in trim by repeated wet mopping though.
RinnyTin
#4 posted 02-09-2012 09:34 PM
@ Loren, we are going with wall to wall carpet, so no mopping. Have you used shellac on trim, and if so, how many coats, and how did it hold up?
27250 posts in 3993 days
#5 posted 02-09-2012 10:31 PM
Rinny, I have done miles of trim and use polyurethane. It goes on quick and is easy to apply and will practically stop a speeding bullet.
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3535 days
#6 posted 02-09-2012 10:40 PM
Gel stain is what I am currently using on oak trim. I made some comments in Rich Greer’s post on gel stains (lumberjocks.com/topics/34460). Use gel stain if you are going for color, otherwise, as Scott Bryan suggested polyurethane.
RinnyTin
#7 posted 02-09-2012 10:45 PM
forgive my ignorance, Arm-R-Seal is polyurethane, right?
#8 posted 02-10-2012 12:53 AM
Shellac holds up roughly as well as lacquer if not subjected
to water or alcohol. It lasts well and is the easiest film finish
to repair. The Zinnser in the can delivers a gloss appearance
in 3 coats. Dries in about 5 minutes so the work goes
rapidly and dust in the finish is not a problem.
#9 posted 02-10-2012 02:10 PM
Rinny, you are correct. Arm R Seal is a oil base wiping urethane varnish that can be applied by wiping, spraying or brushing with a foam brush.
