Breadboard Ends on a Cutting Board
Forum topic by Dchip posted 02-09-2012 03:01 PM 4647 views 0 times favorited 1 reply Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3458 days
02-09-2012 03:01 PM
Should I consider sealing the endgrain on the outer edges of this cutting board since there will be only a dowel and no adhesive? I was thinking of using some thinned titebond 3, then letting it dry before I insert the breadboard end. The joint is a snug fit, but I’m concerned water will get into the space and slowly expand the gap. I plan to just use a mineral oil and beeswax finish. Thanks
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
1 reply so far
View Lee Barker's profile
Lee Barker
2170 posts in 3056 days
#1 posted 02-09-2012 03:36 PM
I give that idea an EXCELLENT rating. Yeah!
Kindly,
