dowel alignment problem
Forum topic by pons posted 02-09-2012 12:23 AM 1240 views 0 times favorited 5 replies Add to Favorites Watch
View pons's profile
pons
25 posts in 2340 days
02-09-2012 12:23 AM
Topic tags/keywords: box dowel alignment question
Hi. I’m fairly new to wood working and am putting together a little box. My question is, if the dowels and holes don’t quite line up, what do you do? Glue dowels in the holes, cut them flush and start over? Any ideas would help greatly.
Thanx.
-- Jim in Va
5 replies so far
View Don W's profile
Don W
18754 posts in 2593 days
#1 posted 02-09-2012 12:29 AM
That will work. Do you know how it got off so it doesn’t happen again?
View pons's profile
pons
#2 posted 02-09-2012 12:39 AM
my guess not paying enough attention with the dowel points. After that , I blame the drill.
thanx
-- Jim in Va
View Dave's profile
Dave
11429 posts in 2866 days
#3 posted 02-09-2012 02:46 AM
There are some self centering jigs at the big box stores. They are fair for lining up dowel holes. Harbor frieght has a pretty good one. A brad point bit is your friend, forstner is better.
View richgreer's profile
richgreer
4541 posts in 3100 days
#4 posted 02-09-2012 03:02 AM
A simple idea that I use every time – - Put a slight taper on the end of the dowel before driving it home. If the dowel is small enough, I use a simple pencil sharpener. If it’s bigger I give it a “spin” on a belt sander.
117118 posts in 3603 days
#5 posted 02-09-2012 03:42 AM
Looks like Dave and Rich have this handled
