Advice sought: Somewhat odd mitre cut question
Forum topic by Milo posted 02-08-2012 10:19 PM 1057 views 0 times favorited 5 replies Add to Favorites Watch
View Milo's profile
Milo
869 posts in 3222 days
02-08-2012 10:19 PM
Topic tags/keywords: question
Had something unexpected happen when I was cutting long mitre cuts on a box I was making.
The first cuts were awesome. The edges lined up right at 45 degrees. I was thrilled. Unfortunately, when I went to cut the opposite sides of the boards, the previously cut was so sharp it slide under fence just a bit, and I got a crappy cut on the second side.
Any thoughts on how to avoid this?
Thanks,
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
5 replies so far
View stefang's profile
stefang
15784 posts in 3237 days
#1 posted 02-08-2012 10:24 PM
Hi Milo, this is easy. Just clamp an auxiliary fence to you saw fence. I has to have at least one straight edge so that the edge will lay perfectly flat on your table. There are other ways, but this probably the easiest.
View lumberdog's profile
lumberdog
245 posts in 3170 days
#2 posted 02-08-2012 11:46 PM
If you can, put the fence on the other side of the blade then turn your board over and cut it.
-- Lumberdog.. Morley, Michigan
View RKW's profile
RKW
328 posts in 3350 days
#3 posted 02-09-2012 12:23 AM
im with stefang….auxillary fence
-- RKWoods
View Milo's profile
Milo
#4 posted 02-09-2012 12:35 PM
I have some hardboard I will try for the auxiliary fence. Thanks gang!
View Ben's profile
Ben
302 posts in 2233 days
#5 posted 02-09-2012 12:50 PM
In the past, I’ve used a good flat piece of ply as a topper for the saw. raise the blade up through it like a zero clearance plate. as long as it puts you above the bottom edge of your fence you could use just about anything. Adjust your fence, lower the blade, lay down the topper and you have no gap to slide under. Better than an auxiliary fence IMO
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
