Turning Question
Forum topic by johnintecumseh posted 02-07-2012 10:15 PM 1065 views 0 times favorited 6 replies Add to Favorites Watch
View johnintecumseh's profile
johnintecumseh
127 posts in 3619 days
02-07-2012 10:15 PM
Hello all. Is there a way to keep chucks or faceplates from binding to the lathe spindle ?? Thanks keep smiling John
-- retired and smiling
View hairy's profile
hairy
2782 posts in 3734 days
#1 posted 02-07-2012 11:05 PM
You may be putting them on too tight.
I screw mine on just until it stops, then tighten the set screws, Set screws do not need to be tight, just snug. I usually sand in reverse, thus the need for set screws.
If you are spinning them on fast to seat it, that’s too much.
Here’s capn eddie! http://www.youtube.com/watch?v=6PATmmU9kH4
-- My reality check bounced...
View TrBlu's profile
TrBlu
386 posts in 2828 days
#2 posted 02-07-2012 11:11 PM
You can buy a plastic washer for the spindle. But, they are easy to make.
I made mine from a lid for a 5 gallon bucket. Cut a piece of plastic, larger than the spindle section of you chuck, drill/cut a hole the size of your spindle. The place your plastic washer on the spindle and tighten the chuck.
I used my skew to trim the plastic “washer” on the lathe, until it was round and closer in size.
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
View stefang's profile (online now)
stefang
16135 posts in 3536 days
#3 posted 02-07-2012 11:15 PM
The plastic washer is probably the best solution. I have never had this problem because I always snug the chuck and face plates up gently by hand. If it is even a little loose the force when you turn the lathe on will really jam it tight.
View Eric_S's profile
Eric_S
1565 posts in 3397 days
#4 posted 02-08-2012 12:15 AM
This is the washer the others are referring to. http://www.woodcraft.com/Product/2021098/24738/AntiLock-Lathe-Spindle-Washer-1.aspx
Lew suggested it to me and it makes a tremendous difference :)
-- - Eric Noblesville, IN
View richgreer's profile
richgreer
4541 posts in 3276 days
#5 posted 02-08-2012 01:17 AM
This was a serious problem for me until I got the plastic washer that was recommended to me on this website.
View BarbS's profile
BarbS
2434 posts in 4287 days
#6 posted 02-08-2012 01:45 AM
I cut mine out of a coffee can lid, and have never had a stuck chuck or faceplate since.
-- http://barbsid.blogspot.com/
