End Vise question
Forum topic by BerBer5985 posted 02-07-2012 08:54 PM 3094 views 0 times favorited 11 replies Add to Favorites Watch
View BerBer5985's profile
BerBer5985
445 posts in 2541 days
02-07-2012 08:54 PM
I was planning on doing a twin screw end vise with some vise screws I bought from LV but the more I look at it, I might just do a reg woodworking vise as the end to compliment my Leg Vise I’m going to install. So the question is, I have a 7” Older Columbian Vise that seems fairly small and not as stout as the larger 9” and 10” quick release that I picked up an estate sale a bit ago thinking I’d use for it something….is it big enough to do what I need? I figure I can use this for a while and if I find it inadequate, I’ll take the plunge later and install a larger 9” or 10”. I think the twin screw would be better reserved for a moxon vise. Here’s the pics:
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
11 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 3073 days
#1 posted 02-07-2012 09:28 PM
Hi Greg, personally, I think that little vise will work just fine as an end vise. I assume you would use it primarily to hold boards length wise on the top of the bench? If that is so, the vise you have will suffice as the clamping pressure you exert to hold wood in that manner is minimal. You don’t want to put a lot of pressure on a board that way because it flexes and bows, which is counterproductive to almost anything you would do to a board clamped like that. I use my tail vise the same way and exert only enough pressure to hold the board securely.
I say go for it, not going to cost any more money.
Good luck!
-- Mike
View cabmaker's profile
cabmaker
1740 posts in 2930 days
#2 posted 02-07-2012 09:32 PM
Greg, I would vote for putting that vise to use because you already have it. Certainly beats no vise at all. At least after some use youll know what demands your going to expect and then be better able to discern what you really need in a vise. Or just forgo all that and go straight to an emmert and be done with it. Enjoy ! JB
BerBer5985
#3 posted 02-07-2012 10:20 PM
That’s what I was thinking as Ive been building this bench. I see most people use a small wagon vise made out out of a veneer press screw so I think it would work as the end vise. I think I’ll go for it using a large chop. Thanks for the info! Sounds like I’ll be making a moxon vise after the bench!
View PurpLev's profile
PurpLev
8540 posts in 3769 days
#4 posted 02-07-2012 10:25 PM
I think the answer depends on (as you said it) “what you need”. do you NEED anything bigger? what are your projects like? what will you be using this vise for (remember, this is an end vise, not a front vise)?
View crank49's profile
crank49
4032 posts in 3092 days
#5 posted 02-08-2012 12:02 AM
I have a front vise on the end of my bench; hate it. Thing will rack and bind up if the load is not perfectly centered.
Then I picked up one of the last of the Groz quick release face vises from Woodcraft when they discontinued them. Thats what I have on the front of my bench already so I know it has no racking issues. It looks almost exactly like the vise in your photo except its dark blue.
I think you will like using it as an end vise. It’s what I’m going to do.
View richgreer's profile
richgreer
4541 posts in 3195 days
#6 posted 02-08-2012 01:20 AM
I will only offer that I use my vice almost on a daily basis and I am really glad to have a quick release vice. It’s a big time saver.
Smitty_Cabinetshop
15520 posts in 2739 days
#7 posted 02-08-2012 01:57 AM
Greg – I’m going to join the chorus and say it’ll be fine as an end vise. It's what I did! :-)
View TechRedneck's profile
TechRedneck
769 posts in 2978 days
#8 posted 02-08-2012 02:23 AM
I agree with Rich
A quick release end vise would be the best choice in my opinion. Heck, if you have the vises mount one on each end.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View DIYaholic's profile
DIYaholic
19647 posts in 2796 days
#9 posted 02-08-2012 03:47 AM
TechRedneck said ”Heck, if you have the vises mount one on each end.”
I’m about to build a bench, nothing fancy, but I have 2 Columbian #178’s & a Record #175. I was thinking of installing two of the three on my “bench to be”, one as a face vise and one as an end vise. Reading this thread, relieves my concerns about the end vise. The question now is; What do I do with the third vise? Like I need any more VICES, between caffeine, alcohol & nicotine!!! Guess I could hold onto it until a need arises, as I’m not one to get rid of a perfectly good tool. Even if I don’t have a need for it.
I really just wanted to say, Thanks for asking your question!
BerBer5985
#10 posted 02-10-2012 12:28 AM
Of course I’d love to have one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170778346807&ssPageName=ADME:B:WNAFP:US:1123
An nice old vintage quick release vise. I’m sure it’s built like a tank.
TechRedneck
#11 posted 02-11-2012 03:02 AM
Here is a bench I put together
http://lumberjocks.com/projects/60275
I am in the same situation. There is one cheap little vise that may go on the other end. The quick release and leg vices are used the most. Each vice has its own specialty the combination of the two fits most all my needs.
A moxon may be in the future. They look interesting
