jet 6" jointer
Forum topic by joshtank posted 02-07-2012 04:22 PM 1479 views 0 times favorited 8 replies Add to Favorites Watch
View joshtank's profile
224 posts in 2907 days
02-07-2012 04:22 PM
Topic tags/keywords: jointer
i just got this from craigslist.
original owner, he bought it in 2001. i got it for $150. i’m stoked on what i think was a good deal, and it’s very timely since i have a LOT of rough cut cedar i put through the bandsaw to joint and plane.
two questions..
1 – i think it vibrates a bit more than is should. i plan on putting it on a rubber mat, what else would help?
2 – the fence is locked at 90 just fit, BUT on the outfeed side it JUST misses touching the outfeed table so it rattles a little bit. it’s mostly just annoying and i clamp it down. any ideas on solution? anyone with similar problems.
-- Josh - Jacksonville, FL -
8 replies so far
View chrisstef's profile (online now)
17252 posts in 2940 days
#1 posted 02-07-2012 04:27 PM
Id check the alignment of your pulleys, they should be coplaner, ive used a plumb bob to align the pulleys on my bandsaw with good success. You alos might want to change the belt out that could cause some vibrations.
$150 is a steal for that jointer so let me be the first to say … YOU SUCK!
View WinterSun's profile
163 posts in 2544 days
#2 posted 02-07-2012 04:33 PM
Chrisstefhit on the likeliest causes of vibration. Consider swapping the belt out for a link belt, especially if you’ll be using the machine infrequently, as they don’t take on a set like regular v-belts.
Also, you most definitely suck!!
-- Rory // Milwaukee, WI
View knotscott's profile
7938 posts in 3309 days
#3 posted 02-07-2012 04:34 PM
Very nice deal on a very nice jointer. Definitely a gloat! Good for you!
View BilltheDiver's profile
253 posts in 2819 days
#4 posted 02-07-2012 04:40 PM
I bought an older model of the same awhile back. I noticed that it bogged down when joining a face. On inspection the key was missing from the keyway of the upper pulley. I agree, check the pulleys and make sure they are secured in place.
-- "Measure twice, cut once, count fingers"
View Jonathan's profile
2608 posts in 2984 days
#5 posted 02-07-2012 06:04 PM
Nice score!
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View RibsBrisket4me's profile
1554 posts in 2439 days
#6 posted 02-07-2012 06:13 PM
Awesome score…. get qet a link belt and to an inspection all over!
View PurpLev's profile
8534 posts in 3582 days
#7 posted 02-07-2012 06:22 PM
for vibration – check the pullyies alignment and the belt, you might want to consider replacing the belt with a higher quality one (not necessarily higher priced one) especially if you notice that it is hard.
as for the rattling – sounds like something is too loose there that the vibration is causing it to move enough to make/break contact with the outfeed. I’d look into what it might be.
#8 posted 02-10-2012 03:57 PM
thanks for the help. i’ll def check out getting a link belt. this is making that cedar a breeze.
