| Forum topic by bevins587 | posted 469 days ago | 814 views | 0 times favorited | 13 replies | ![]() |
469 days ago |
I noticed in a piece of wood that I was using that I kept seeing what appeared to be bored holes from bugs. -I tried to do a search on here and came across everything but what I was looking for really, but I assume that from the looks of it, the bugs have done came and got what they wanted from the moisture of the wood originally and have now left. -I have read about different topical solutions that you can apply to prevent the bugs, and was wondering what others have mixed up or used to prevent them? -Also what king of bug has caused the damage from the picture? Thanks |
13 replies so far
#1 posted 469 days ago |
I could tell much from the photo. Was there little places with dust where they have bored? If there was it sounds like powder post beetles. You can get a product called Boracare. This can be ordered from the internet or bought locally from exterminators. They just happen. I hear you need to really wet the wood with this product. |
#2 posted 469 days ago |
You better check the rest of your stock. If you have more then get it out of your shop quickly. |
#3 posted 469 days ago |
The best way to prevent bug infestations is to keep the wood dry. Getting rid of an infestation is another matter and one that I’m not familiar with. -- See my work at http://remmertstudios.com and http://altaredesign.com |
#4 posted 468 days ago |
You guys are scaring me. If my lumber is dry, I shouldn’t have any problem. Right? -- I'll be a woodworker when I grow up. HHHOPKS |
#5 posted 468 days ago |
If it is borer… and if you have an infestation…you need to do (what we call here in NZ) Borer bomb, there are many products that will kill most insects… but the best time to catch them is when they are on the wing (here in NZ it is during the summer) do one near the beginning and near the end of the season and then every year to keep them under control and you find they slowly disappear. We just did our last one about 2 weeks ago… The reason getting them on the wing is because that is usually their mating season so slowly controlling them… As for the house most insects the bore in to wood don’t like or touch treated wood… but for your lumber stock you need to keep an eye on it… -- Rome wasn't built in a day... but I wasn't on that job? ... http://www.southernrider.co.nz/projects/ |
#6 posted 468 days ago |
I’ve not seen any signs of bugs, so could this be damage from the past and now everything is ok? I’m not going to use that piece of wood, but I’m more worried about my other wood and the building it is stored near. |
#7 posted 468 days ago |
I’ve had the odd plank of American white oak pretty much the same as that. I asked my timber merchant about them. According to him, these are boreholes from prior to kiln drying, the critters that made them are long gone. Of course, he might just be trying to fob me off… -- Do or do not, there is no try |
#8 posted 468 days ago |
What you need: Application: Theat’s the only way to get rid of wood critters, or ummm, maybe it was crotch critters. (I never had either so I’ve forgotten which). -- Improvise.... Adapt...... Overcome! |
#9 posted 468 days ago |
The first thing to do is determine whether or not they, or their larvae, are still in the wood. If you see small piles of wood dust laying around, they are there. I cannot tell by the pic, but if the holes you see are slanted then they were made before the wood was sliced; if they are flat and round, then they may be fresh. If the wood has been correctly kiln dried and heat treated, then you will be just fine; note that it needs to be heat treated! If it is just dried the larvae will be unaffected. The wood needs to be at about 135 degrees f. to kill them off. The best thing to do to keep them from infesting your area is to keep it clean; sweep up all sawdust as soon as possible and keep the wood wiped off. You can get a wood bug killer from most wood sales points, you can spray it on and it will penetrate the wood to kill the critters inside and keep them from causing more problems. -- Power tools put us ahead of the monkeys |
#10 posted 468 days ago |
what I do is …. and only becourse I havn´t a freezer that can go down to – 40 degrees celcius below 0 another way is to put the wood in an owen with over 55 degree celcius a couplle of hours theese two ways will kill the bugs and if you fill the holes with plasticwoodfiller or something simular one backslass to this metodes is it doesn´t obstruct future attacks if you leve in a zone where you don´t have low freezing temp. you can sneak to use the boss´s freezer good luck on your beetle rampage |
#11 posted 468 days ago |
http://www.pestmall.com/powder-post-beetle-control-products/ People get them at times. They are in the wood. Treat them, use the wood and move on. |
#12 posted 467 days ago |
yep i,ve hadm to, in a project i made -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
#13 posted 467 days ago |
I treat with Boracare to stop it before it starts in my air drying yard. It will supossidly will kill them also. Kiln drying will also kill anything in the wood now. -- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15763 |
Hand Tools
2034 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
