A Very HOT Tip!!!
« back to Coffee Lounge forum
Forum topic by cabinetman posted 2224 days ago 911 views 0 times favorited 6 replies Add to Favorites Watch
View cabinetman's profile
cabinetman
144 posts in 2315 days
2224 days ago
There’s been a lot of discussion concerning shop safety and how to protect ourselves. There really hasn’t been too much discussion about fire extinguishers. I can’t emphasize enough the value of having one close by. I’ve always kept one in or near the kitchen and garage area, and many in the shop. Knowing how to use one and which ones are for what type of fires is important. I’ve had a few fires and in a shop area, especially a wood shop, a fire can get rampant in a hurry. Here’s a short description of the types.
Fire Extinguisher Ratings
Class A Extinguishers will put out fires in ordinary combustibles, such as wood and paper. The numerical rating for this class of fire extinguisher refers to the amount of water the fire extinguisher holds and the amount of fire it will extinguish.
Class B Extinguishers should be used on fires involving flammable liquids, such as grease, gasoline, oil, etc. The numerical rating for this class of fire extinguisher states the approximate number of square feet of a flammable liquid fire that a non-expert person can expect to extinguish.
Class C Extinguishers are suitable for use on electrically energized fires. This class of fire extinguishers does not have a numerical rating. The presence of the letter ā€œCā€ indicates that the extinguishing agent is non-conductive.
Class D Extinguishers are designed for use on flammable metals and are often specific for the type of metal in question. There is no picture designator for Class D extinguishers. These extinguishers generally have no rating nor are they given a multi-purpose rating for use on other types of fires.
For more details:
http://www.fire-extinguisher101.com/
18320 posts in 2332 days
#1 posted 2224 days ago
excellent info. Thank you for this.
Dick, & Barb Cain
8681 posts in 2471 days
#2 posted 2224 days ago
Very good advice, on my job especially while welding, I’ve used an fire extinguisher many times. That’s one thing I have add to my list for my shop.
dennis mitchell
3994 posts in 2486 days
#3 posted 2224 days ago
I’ve never needed one, but I’ve got two!
View Obi's profile
Obi
2202 posts in 2408 days
#4 posted 2224 days ago
Thank God my brother-in-law had one this was posted a couple of months ago when my table saw caught fire
-- http://ye-olde-cabinet-shoppe.com/
34370 posts in 2572 days
#5 posted 2224 days ago
Never had to use one in the shop. Thank you Lord.
I have a couple of larger ones that I can’t refill because the “Test By Date” has expired and the testing costs more than buying a new extinguisher.
But you are right I’ve probably got 2 in the shop but not close enough to grab them fast.
I also do welding like Dick both Acetylene and Electric and I do it outside. Other than the silver soldering for making my own Band Saw blades.
I guess I need to purchase a couple of more to have handy, and then know where they are.
View Wooder's profile
Wooder
163 posts in 2358 days
#6 posted 2224 days ago
I have 2 also. A 10 lb and 5 lb ABC. Been checked and refilled once, but not from use..
-- Jimmy
