HELP! This Can't Be This Hard
Forum topic by gfadvm posted 472 days ago 1432 views 7 times favorited 27 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
6650 posts in 861 days
472 days ago
A lady asked if I could make one of these toys for her son. I have been fighting it all afternoon. She had this picture but no plans or dimensions. I took a pic of the scrapwood prototype I worked on today. Does anyone have plans / dimensions for this? I would like to be smarter before I start wrecking nice woods. Thanks, I hate to admit to her that I can’t do this (plus I would like to make one for my granddaughter).
27 replies so far
View Lifesaver2000's profile
Lifesaver2000
463 posts in 1283 days
#1 posted 472 days ago
I had one of these when I was a kid back in the 70’s. It was called a “Do Nothing” at the time.
Here are a couple links that might help:
http://en.wikipedia.org/wiki/Trammel_of_Archimedes
http://www.woodenuknow.com/donothingmachines.html
Good luck.
View Danpaddles's profile
Danpaddles
389 posts in 483 days
#2 posted 472 days ago
smoke grinder. Got a dovetail bit? s’all you need. well, that and a saw. and some wood.
-- Dan V. in Indy
View grizzman's profile
grizzman
5397 posts in 1475 days
#3 posted 472 days ago
i just looked at the wiki site of this…LOL
-- GRIZZMAN ...[''''']
View LittlePaw's profile
LittlePaw
1500 posts in 1249 days
#4 posted 472 days ago
Looking at it, it sure doesn’t look all that hard to make, does it?. Maybe I’m wrong, but I after cutting the 90 degree grooves, the 2 pcs of sliders and the crank handle, I’d start by attaching one pc of wood centered in the cross section and on the end of the crank.
Then slide the other pc of wood about half way out one track, put temporary pin through the handle and into the 2nd pc. Then gently turn the crank and see if it would clear each other and go all the way around, If not, just adjust where the pin is located until it would! That’s my best guess, Doc. Do let me know how it turn out.
-- Paul - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View Chipy's profile
Chipy
378 posts in 765 days
#5 posted 472 days ago
Just a funny side note to you Trammel of Archimedes, Woodsmith(vol 34/no.199) magazine used this same principal to create a arc to create a template for a Demilune table.Anyways I think you could cut all thees parts in your table saw it look like a 45 or 30 degree angle for the slot parts.
View xwingace's profile
xwingace
199 posts in 760 days
#6 posted 472 days ago
That thing is awesome!
-- I'm not as good as I once was, but I'm as good once as I ever was.
View Elizabeth's profile
Elizabeth
639 posts in 1315 days
#7 posted 472 days ago
Thanks for posting this! I had one of these as a kid and would love to make one, but I didn’t even have a picture, let alone a name.
I think mine had circular routed channels and the two moving pieces were shaped like tic-tacs.
View Roger's profile
Roger
9192 posts in 975 days
#8 posted 472 days ago
all’s I can think about is “the wheels on the bus go round-n-round, round-n-round, round-n-round” lol that is kool tho. I’ve never seen one, but, I could see where it would work maybe in some wood automation. thnx for the links, link posters
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#9 posted 472 days ago
I’ve seen those, I’ve heard called a BS grinder.
-- Bondo Gaposis
View Charles Maxwell's profile
Charles Maxwell
826 posts in 1978 days
#10 posted 472 days ago
View ShopTinker's profile
ShopTinker
862 posts in 940 days
#11 posted 472 days ago
Just looking at the pictures I think you need to move your center bolt down towards the handle end. I’m guessing about 1/2 an inch.
Let us know when you get it figured out so we can all make one..
There will be an onslaught of Lumber Jock B.S.ers cranking out BS Grinders.
-- Dan - Valparaiso, Indiana, "A smart man changes his mind, a fool never does."
gfadvm
#12 posted 472 days ago
OK guys, I have the pine nailed together prototype working smoothly (wax helped a lot!). It looks to me that a rabbited design would work better as the dovetails bind easily if the handle is not held perfectly flat and parallel to the device. What do you guys think? The first link showed a plywood version that was not dovetailed but this lady wants “fancy wood”.
View Joe Lyddon's profile
Joe Lyddon
6397 posts in 2223 days
#13 posted 472 days ago
I was making six of them when I had my Router accident…
... cutting the internal sliding dovetails…
After the accident, went to the table saw to do it… was a lot easier too!
Fun lil project…
LittlePaw
#14 posted 472 days ago
If it works, that’s all that matters, isn’t it? Now u can duplicate it with any fancy wood! I knew u could do it, Andy!
gfadvm
#15 posted 472 days ago
Hey Paul, It only works because I repositioned the parts with 97 brad nails and sanded a lot of tight spots! I’m trying to avoid this ‘tweaking’ with the fancy wood. No one voted against it so tomorrow I’ll try rabbits in scrap rather than the dovetail configuration. Also it appears some of these have a ‘handle’ on the underside???
