Cutting a rabbet with a 3" start / stop on each end on table saw
Forum topic by jeffroL posted 467 days ago 755 views 0 times favorited 14 replies Add to Favorites Watch
View jeffroL's profile
jeffroL
10 posts in 468 days
467 days ago
Topic tags/keywords: rabbet question tablesaw
I’m trying to cut a rabbet (3/4” x 3/4”) on 5’ and 6’ lengths of timber, with a start and end 3” from each end. I would normally do this on my router table, but decided to use the table saw instead, as it is really slow trying to do this for 16 of these 5 and 6’ lengths of timber, given that the cuts are so deep and wide. It seems to be such a grind on the router and I assume the bit as well.
Can anybody advice on how I do that on the table saw, such that I have a 3” start and stop at each end. I was going to drop the timber from the top onto the spinning blade (with the riving knife off), but wasn’t too sure it was safe.
Thanks
Jeff
14 replies so far
View TheDane's profile
TheDane
2672 posts in 1828 days
#1 posted 467 days ago
Some set the blade at the proper height, then count the number of revolutions as you crank it down below the throat plate. You could then position the workpiece, hold it down with featherboards/push sticks, start the saw, and raise the blade into the piece the proper number of revolutions and finish the cut.
—Gerry
View Viking's profile
Viking
858 posts in 1361 days
#2 posted 467 days ago
Jeff;
Why can’t you do this on your router table? Lower the bit and do a half depth cut on your pieces then raise bit to final depth and run them through again.
Seems this would be safer?
Good luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
86934 posts in 1742 days
#3 posted 467 days ago
You can do it on the table saw but I think stop rabbits are a lot bigger pain on the table saw then on the router table. If your router table is small you might consider a in feed and out feed for your router table.
4868 posts in 1813 days
#4 posted 467 days ago
You can drop the timber onto the spinning blade. The heavier
the board the more control you’ll have due to mass and inertia.
Practice the cut on a 2×4 to see how it feels.
Use featherboards.
A slower way to go is start with the blade below the table
and crank it up into the cut. A variant is to sort of do
all the cuts in 1/16” increments, making the plunge
quite mild and controllable and doing all the boards at
a given depth, then raising the blade a bit and running
them through again until full depth is reached.
View gfadvm's profile (online now)
gfadvm
6602 posts in 855 days
#5 posted 467 days ago
Do NOT ‘drop’ it onto a spinning blade! That will create way more excitement than you bargained for. If you routed the 2 ends and then connected those with the table saw, that should work. The routed rabbit would give you something to raise your blade to without the blade running. Be careful!
Viking
#6 posted 467 days ago
3/4” in 1/16” increments = 12 passes?
View DIYaholic's profile
DIYaholic
7249 posts in 840 days
#7 posted 467 days ago
I’m a newbie, so what do I know!
Even though I’m a newbie, I like the sound of gfadvm’s solution the best. It sounds like the best & safest way to do it.
-- Randy-- I may not be good...but I am slow!
View cabmaker's profile
cabmaker
1020 posts in 974 days
#8 posted 467 days ago
I dont know what your building, but have you pondered running it all through the length then filling in the three inch rebate on each end ?
gfadvm
#9 posted 467 days ago
Cabmaker, You are a genious! Why didn’t we ALL think of that? I withdraw my suggestion. I’m going to pm you the next time I’m trying to figure out how to do something the hard way! That’s why this is such a great site. We have some very smart folks who are willing to help.
jeffroL
#10 posted 467 days ago
Thanks for your inputs folks. I might try gfadvm;s suggestion next and will let you all know how I go. I have 16 of these 5” and 6” lengths to go thru, so I want to avoid trying to raise the router bit 1/16”.
View Lee Barker's profile
Lee Barker
1881 posts in 1016 days
#11 posted 467 days ago
Just a meaningful second to gadfvm’s opinion.
Trying the dado method cost me a trip to the ER many years ago, but the memory is vivid.
Use the router, sharp bit, small increments, and listen closely for high frequency chatter—it tells you you are taking too big a bite.
Kindly,
jeffroL
#12 posted 467 days ago
I meant 5’ and 6’ lengths…...
View Sawkerf's profile
Sawkerf
1776 posts in 1234 days
#13 posted 467 days ago
What cabmaker said. It’s much simpler and safer.
jeffroL
#14 posted 467 days ago
Yes, as I think more about this, I’m leaning towards cabmakers’s way. Thanks folks.
