| Forum topic by agallant | posted 467 days ago | 907 views | 0 times favorited | 12 replies | ![]() |
467 days ago |
I have tried the stock miter gauges, I have tried to make my own jigs and my 45 cuts are always a bit off. It is driving me crazy so my question is what is the best method of cutting 45? I do have a CMS but I hate the thing, I like to use the table saw. Can you share what jig you are using or have made? |
12 replies so far
#1 posted 467 days ago |
I have a Ridgid TS 3650. It stays set square for my finger joint jig because that’s the only useful thing I’ve ever found it good for. My miter saw used to have a dedicated stand. About a month after getting the Osbourne, it went under a table and has collected dust there ever since. |
#2 posted 467 days ago |
I like my Osbourne too. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 467 days ago |
The Osbourne, since Jim also likes it, I wanted to point out what makes it great. First off, the stability. Because if it’s triangular locking design, along with a longer fence, it is super stable. The other thing is the positive stops. It easily goes from ninety, to forty five, back to ninety, and back again. All this is accomplished with positive stops that makes it simple to go back to any angle between ninety and forty five with assured repeatability. With the stock miter gauge, it took an act of congress to get it back square if you ever took it off of ninety. Actually, you could leave it on ninety and bump it wrong, and it was off. Without precision accurate measureing with secondary tools, it was also impossible to get it perfectly on forty five with any kind of dependability. |
#4 posted 467 days ago |
Ditto on the Osbourne ! -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#5 posted 467 days ago |
I’m sorry. I just got a PM concerning the links I provided above. I found my problem and they are working now. |
#6 posted 467 days ago |
Agallant, although there are several methods and different machines to choose from for cutting miters, I have found that a decent TS( well tuned) is the best bet for quality miters. And if You are not willing to spend money on a quality manufactured jig/fixture (like the Osbourne)Your best bet is to revisit your attempts at making a sled fixture that is dedicated to cutting 45 deg. miters IMO ! I put together a miter sled several years ago and it has performed very well to date(My projects page). Using stable materials and taking your time to focus on accuracy when building the fixture should help improve your end results. Build your base first and then establish the miter rails at 45 to the blade with the aid of two large drafting squares. Also to help with accuracy be sure to have adjustability with in the design of the sled. Helpful tip, I use double sided tape when dialing in the rails before I secure permanently. Wish You luck in Your quest for that elusive “Perfect Miter” !!............ROB -- Rob,Gaithersburg,MD,One mans trash is another mans woodshop treasure !! |
#7 posted 466 days ago |
agallant, -- Politicians are like diapers. They need to be changed for the same reasons. |
#8 posted 465 days ago |
buckles, Where are the pics? -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#9 posted 464 days ago |
For fun, I like to get it close and then play with a low angle block plane and a 45deg shooting board. Helps a lot. It only takes a couple passes works nice and sweet. |
#10 posted 464 days ago |
I have an old Delta CMS that’s made out of cast iron and weighs about half a ton and won’t cut anything wider than about 5 1/2” or thicker than 3 1/2”, but what it does cut is perfect. I cut all my project cut list material on this saw if it is not too wide. I have a nice sled that mostly stays on a shelf. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#11 posted 464 days ago |
I made my own fence for my Bosch CMS, it is now very accurate, and handy. Only takes a second to swing it from 90 to 45. And I know it is “right on” every time. Unless of course my workpiece creeps a little while it is cutting, I have to watch for that. My table saw is for big stuff and for ripping. Or maybe repetitive jobs, I’ll make a special sled. But I use the heck out of my CMS. Now that I have a fairly well tuned old Dewalt RAS in the shop, I may have a different opinion in a month or so. -- Dan V. in Indy |
#12 posted 464 days ago |
I have one of these Miter Set’s. It works as advertised and makes your OEM miter gauge able to cut at any angle perfectly. -- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15751 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
