Golf pencil display
Forum topic by Trev posted 02-05-2012 10:47 PM 7898 views 0 times favorited 6 replies Add to Favorites Watch
View Trev's profile
Trev
11 posts in 2335 days
02-05-2012 10:47 PM
Topic tags/keywords: question
I want to make a golf pencil display case with my daughter (I finally got her excited about my two hobbies – golf and woodworking), however I can’t seem to find any designs on the actual part that holds the pencils A 5/16 grove is close, but perfect. Has anyone made one of these displays or knows how to make the pencil holders easily? Any info would be great. Attached is a sample golf pencil case so that you know what I am talking about.
-Steve
View FirehouseWoodworking's profile
706 posts in 3268 days
#1 posted 02-05-2012 11:22 PM
Steve,
I’d take a nice piece of hardwood of your choice, about an inch long. Drill a hole of the appropriate size that would be “about snug” (note use of the technical measurement! LOL) the length of the piece of hardwood.
Next, I would run the piece through the bandsaw (or tablesaw if you don’t have a bandsaw, but be careful) and remove wood not quite to the centerline of the hole. This would leave about 200 degrees of the hole, if you will.
I would taper the wood on the top and bottom for appearance. Sand the piece and line the hole with self-stick felt. You should be able to snap the pencil into the hardwood.
Now build 39 more and you’ve got it! Good luck.
Cheers!
-- Dave; Lansing, Kansas
View Trev's profile
Trev
#2 posted 02-05-2012 11:33 PM
Thanks Dave. That makes sense.
View Trev's profile
Trev
#3 posted 02-06-2012 12:07 AM
Dave, I just tried it and it worked great. I don’t have a drill press and need to ensure the holes are drilled straight. I took 4/4 stock and drilled a row of holes and ripped the holes as you described and it left me with with a pencil holder strip. I didn’t make them indiviually as you described, but your method was spot-on. Thanks so much for your quick response.
Steve
117090 posts in 3572 days
#4 posted 02-06-2012 12:47 AM
A most unique display Steve and good tip Dave
#5 posted 02-06-2012 12:47 AM
SLACKER! You took the easy way out!
Kidding! Glad it worked out for you. Enjoy.
Cheers!
View TexUSAF's profile
TexUSAF
104 posts in 1961 days
#6 posted 06-29-2013 07:43 PM
May I ask what size drill bit you used? I have tried several and it’s either too tight, or too loose.
Thanks,
Tex
