Saw sharpening, re-toothing, setting, etc. -- found!
« back to Hand Tools forum
Forum topic by handyrandyrc posted 472 days ago 1113 views 0 times favorited 19 replies Add to Favorites Watch
View handyrandyrc's profile
handyrandyrc
33 posts in 474 days
472 days ago
Anyone use www.logsandlumbersawmill.com ? I have had a good experience with them so far. I purchased a backsaw from an antique shop that I wanted to dedicate as a tenon saw. It has a fairly broad sawplate. It was filed crosscut 13tpi, so I wanted it switched to 10tpi rip.
The guy at the shop, Jim, recommended maybe I do a half rip since I’m a newbie to the world of woodworking, as it might make it easier for me to control. He said as I file it, I can go more towards full rip as I get better. His prices were also VERY reasonable. If you’ve not given them a try, you might check them out. They are in York, NE.
I am expecting to receive the saw next week, so I’ll update the post with a recommendation on their services.
Randy
19 replies so far
handyrandyrc
#1 posted 446 days ago
Just wanted to follow up.
I sent the saw on the 28th of Jan and received it back the 23rd of Feb. ALMOST a month, but not quite. I had to send e-mail quite a few times to get updates. There were many excuses, too cold, equipment not working, funeral to attend, etc. It came back with almost an inch in depth removed from the sawplate! I bought this saw because it still had a deep sawplate—almost 4”—and I wanted to cut deep tenons with it. I don’t know if I can even cut 3” now without bottoming out on the back.
He said he wasn’t happy with the sharpening job—he called it “calves and cows”. But sent it back and said I could try it out and see if it would work for me. He also said I could send it to be sharpened again and he’d work it out to be better next time. It does indeed seem to have large gullets and small gullets alternating for some of the length. I’ll have to post some before and after pictures.
Because he felt bad, he threw in another saw as a gift. It’s a nice gesture for having my saw for so long and he said it was filed the way (10tpi rip) he wanted my saw to be. I don’t like to look a gift horse in the mouth, but the toothline is bent pretty bad in a couple spots, and the saw wants to therefore bind in the cut. Makes it no good for me.
My saw, with a perfectly straight toothline, cuts worse than before. And now it’s missing almost an inch of depth. I’m ready to give up on it now and look for another.
View interpim's profile
interpim
1115 posts in 1628 days
#2 posted 446 days ago
The fact that he sent you a new saw, says to me that he knew he screwed up your saw. I’m not sure what kind of arrangement you had with him, but I would be pretty livid about the situation.
The least I would do is never do business with him again. Depending on the monetary involvement you had, I would probably go so far as demanding a new saw similar to the one you initially sent in.
Removing an entire inch from a saw plate is overkill. It sounds to me like he ground it, didn’t like the outcome, so re-did the job again poorly. For the most part, he sounds like an amateur.
-- San Diego, CA
View MrRon's profile
MrRon
1575 posts in 1413 days
#3 posted 446 days ago
I used to sharpen saws and what happened to you is classic inexperienced saw sharpener. to change the tooth pitch , he first had to remove the 13 pitch and punch a new 10 pitch. Because this was an antique saw, I would guess the steel is brittle. If that is the case, the process of setting the teeth, would cause some of the teeth to break off. That would then result in re-cutting new teeth and setting. Each time it is repeated, the plate gets narrower. If you lost over an inch in width, I think he must have recut/reset the blade 4 times or more.
If I were doing that saw, the first time around and teeth broke off, I would declare the saw no longer usable and return it to the owner. When saw blades loose their temper, they can no longer be sharpened. The blades can be retempered, but that is usually beyond the skill of the sharpener.
handyrandyrc
#4 posted 446 days ago
To be forthcoming, he offered a “first sharpening free” to me, which he said was because I was a first time customer. Because I sounded like such a newb, I also assumed he was trying to help me out getting started.
$20 on the saw at the antique shop.
$18 on shipping back and forth.
$10 cash “tip” I threw in the box because he wanted to do it for free.
He did have to spend extra money on the return shipping because he gave me the extra saw. I guess my $10 tip can count for covering that.
So I’ll be eating a $50 mistake. I just won’t send anything there again, but I wanted to let others know about it as well. I’m not going to seek anything else from him.
View Bill White's profile
Bill White
2604 posts in 2130 days
#5 posted 446 days ago
Bummer!! Next time try Matt Ciani http://thesawblog.com
I’m gonna send him my Butcher tenon saw. Guy does good work.
Bill
-- bill@magraphics.us
MrRon
#6 posted 446 days ago
The fact that he sent you a new saw, says to me that he knew he screwed up your saw. He didn’t get a new saw, but an old one that was kicking around.
interpim
#7 posted 446 days ago
I meant new, as in he didn’t own it prior to this transaction
-- San Diego, CA
View Brit's profile
Brit
4195 posts in 1012 days
#8 posted 446 days ago
Please post some pictures of both saws. See if you can take a close up of the cows and calves and for the junker saw he threw in, take a photo looking from one end along the toothline so we can see how bad the wave is. Sometimes a wave can easily be fixed and you can do that yourself. I can tell you how, but I need to see a photo first to see what it looks like. I can’t believe he wasted an inch. He obviously doesn’t know what he’s doing. 1/4” would be excessive IMO, even with filing all the teeth off and cutting new ones.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
View JoeMcGlynn's profile
JoeMcGlynn
83 posts in 523 days
#9 posted 446 days ago
That stinks.
You can replace the saw plate and get the depth back if you want. Are the handle and back decent?
Do post some pics…
-- Blog: http://mcglynnonmaking.wordpress.com/
handyrandyrc
#10 posted 446 days ago
Before.
After.
Cows / calves.
You can see how deep the sawplate was before—I could cut those deep tenon cheeks. Now it’s useless for that, and doesn’t cut well to boot. Same board with cut tenons for scale in both pictures.
View Brandon's profile
Brandon
3759 posts in 1121 days
#11 posted 446 days ago
They wrecked that saw! You can see the saw teeth in the shadow pretty well. Luckily there’s still enough saw plate left that it’s still usable, but unfortunately not for what you had intended it for.
-- "hold fast to that which is good"
View Brit's profile
Brit
#12 posted 446 days ago
Well the guy who filed that was either blindfolded or simply doesn’t know the first thing about filing saws. My advice would be to put it down to experience and use that saw to learn to file the teeth yourself. It isn’t difficult really and it’s a great skill to have. If you want the saw to be 10TPI rip, you will need a 6” Extra Slim Taper file. The best instructions for filing saws can be found at vintagesaws.com and is called 'Saw Filing - A Beginner's Primer'. Read and re-read it until it makes sense, clamp your saw between two bits of wood and have at it. You’ll be glad you did. One thing though, You’ll need to file off the existing teeth completely and file in new teeth before you sharpen it.
Regarding the junker saw, depending on how bad the wave is, you might be able to straighten it using either this method or this method. In both cases, you’ll need to scroll down to see the appropriate part of the blog post. Sometimes you need to remove the back completely. If the saw is badly kinked, it probably isn’t worth doing.
JoeMcGlynn
#13 posted 444 days ago
Whoever sharpened that was clueless. Thanks god it wasn’t a rare or expensive saw!
View dbray45's profile
dbray45
2018 posts in 946 days
#14 posted 443 days ago
There may some other things going on that you don’t see. If I remember correctly, the older blades may not have hardened high carbon steel throughout. This is also why the teeth continued to break off. Once he was past the hardened steel, he could set the teeth. Chances are the the teeth will dull quickly unless the blade is re hardened and tempered – not easy to do without distorting the balde.
I have straightened blades by refiling them. Depends upon whether the blade is creased.
-- David in Damascus, MD
MrRon
#15 posted 443 days ago
Brit, You don’t use a file to remove the teeth and file new teeth. You will never get them all the same. For this job, you need a machine that punches new teeth while removing the old. This will usually remove 3/16” from the blade width. There are machines that make short work of setting the teeth, although it can be done with a hand held setting tool. I used to be in the saw sharpening business and still have all the machines, but I am now retired and do only blades for my own use.
