Reliable way to remove all japanning?
« back to Hand Tools forum
Forum topic by Brett posted 471 days ago 2086 views 1 time favorited 13 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 851 days
471 days ago
What is a reliable way to remove all japanning from a plane?
I have a #6 that has only about #20 japanning remaining. I’ve used a citric acid bath to remove rust and paint stripper to remove some of the japaning, but there’s still about 10% left, mostly in hard-to-reach areas.
Can anyone recommend a solvent that will remove all the japanning without requiring a lot of scraping and sanding in nooks and crannies? I know sandblasting would work, but I don’t want to invest in the equipment.
(BTW, I’m planning to repaint or re-japan, which is why I’d like to remove all the old stuff first.)
-- More tools, fewer machines.
13 replies so far
View hhhopks's profile
hhhopks
546 posts in 545 days
#1 posted 469 days ago
Isn’t the whole purpose of japaning is to restand all the harsh chemicals?
I would suggest using a wire brush or a dremel. You may try various type (disk, brush….etc). You should able to pick up some kind of rotatary tool pretty cheap (HF).
Sand blast will do it too but may remove too much and leave the tool pitted. I used to do that at work but have lost access since I changed job.
Personnally, I don’t like using chemical. Not a very enviornment friendly option. That is just my preference.
-- I'll be a woodworker when I grow up. HHHOPKS
View BigYin's profile
BigYin
170 posts in 584 days
#2 posted 469 days ago
dont sandblast, find someone locally who will blast with “Crushed walnut shell” or Crushed corn cob”
wont hurt the metal at all.
-- ... Never Apologise For Being Right ...
View DrDirt's profile
DrDirt
1781 posts in 1910 days
#3 posted 469 days ago
Ditto on blasting -
Because it is a convenient small part – TONS of companies out there have a blasting cabinet and could even powder coat for you, which would be even nicer than typical japanning or use of Krylon to finish.
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View HorizontalMike's profile
HorizontalMike
4930 posts in 1082 days
#4 posted 469 days ago
Electrolysis works great at removing all japanning WITHOUT doing any harm to the underlying metal. All it takes is a 2-10amp car battery charger, some copper wire, a couple of scrap pieces of steel plate (or the like), a 5gal bucket of large shallow plastic tub, and some some Washing Soda (local grocery store item—cheap).
http://www.woodworkingseminars.com/wp-content/uploads/2007/11/shopnotes-72-removing-rust-with-electrolysis.pdf
http://lumberjocks.com/David/blog/2191
http://lumberjocks.com/Sandking/blog/9327
Here is one I did with electrolysis:
http://www.horizontalheavens.com/Refurbed%20sargent_418vbm_plane.htm
View Zulu55's profile
Zulu55
71 posts in 485 days
#5 posted 469 days ago
Wow, great link HorizontalMike! Thanks for sharing!
-- Adam - Langley, British Columbia (Canada)
View bigkev's profile
bigkev
196 posts in 796 days
#6 posted 469 days ago
I’ve done several planes and found that blasting with the walnut shells works best if you have access to it. Takes 5 minutes, no damage and super clean.
-- Kevin, South Carolina
View paratrooper34's profile
paratrooper34
698 posts in 1120 days
#7 posted 469 days ago
I use electrolysis on planes that I restore and only a couple of them had all of the jappaning removed from the process. There was some left informers are such and I used a dental pick to get it out. Painted over them all with regular old spray paint. If you use this process, I suggest you use baking soda with the water. Arm and Hammer is what I use.
-- Mike
View Bill1225's profile
Bill1225
117 posts in 567 days
#8 posted 469 days ago
I have had luck asking my local mechanic to blast things he uses a synthic walnut shell like product and also has a ultra sonic cleaner which cleans beyond belief just be careful to get some oil on it asap to stop flash rust. normally he has one of the shop kids do it and takes about 10 min and i tip the kid 5-10 bucks
HorizontalMike
#9 posted 469 days ago
Paratrooper,
What I found works best is kicking the charger up to 10amps overnight to get any tough japanning off (I left everything OUTSIDE for good ventilation). At the 2amp setting, not much progress was noted.
Black automotive semi-gloss is the best to use for replacing the japanning if you are not going with the original asphalt japanning. Three to four coats about 5min apart, just long enough that you do not run. You want a very thick final coating, enough that you have a hard time reading any stamps (Sargent, Stanley, Record, etc.) while the paint is wet. The paint will shrink as it dries over the next 7 days and you will end up with a very nice coating.
View Don W's profile (online now)
Don W
9947 posts in 735 days
#10 posted 469 days ago
some info here.
Brett
#11 posted 468 days ago
I don’t have much experience removing paint from metal objects and then repainting them. If I remove all the japanning I can from my plane and the remaining japanning feels smooth and won’t come off even with sandpaper, is it safe to paint over? If I use paint, should I use a base coat first? If I do true jappaning, can I put the new coat(s) right over the old stuff? I don’t mind coating over the old bits of japanning, as long as the new coat (paint or japanning) will adhere to it as well as to the bare metal.
View ShaneA's profile
ShaneA
3963 posts in 766 days
#12 posted 468 days ago
I have had good results using the “hammered” paints, if your surface isnt super smooth, this type paint can help cure that. If the loose stuff is scraped off, cleaned, and smoothed out best you can, should be able to paint at that point.
Don W
#13 posted 468 days ago
I have painted over some left over paint. If you are sure its solid and have sanded over it. I have used the hammer paint and it worked well, but I still like the Dupli-Color Engine Enamel DUPDE1635 Ford Semi Gloss Black spray paint better. You can coat every 10-15 minutes, so you can build it up fast. This is important if your going over existing because you’ll want to add a few more coats so it evens out.
Just one note if you use it, if you let it sit for more than an hour between coats, you will need to wait 7 days before recoating. So don’t forget what your doing in the middle. It will bubble, and its a bitch to get off (which if you think about it, is a good thing).
I’ve never used real japanning. Its quit a process for very little gain.
