Bench top board alignment.
Forum topic by Matt Stauffer posted 02-05-2012 05:10 AM 1989 views 0 times favorited 16 replies Add to Favorites Watch
View Matt Stauffer's profile
Matt Stauffer
110 posts in 2640 days
02-05-2012 05:10 AM
I’m 3/4 done with my Nicholson style bench and am stuck on the top. I’ve got the best southern yellow pine that South Alabama has to offer (which is far from perfect). I’ve got all the joining edges planed smooth, but the boards have bows that I can do nothing about. I clamped all the boards together in a stack hoping they would flatten out or something, but no luck. I am thinking about using oak dowels along the length of the 8 foot planks to make them behave. I don’t know if this will work long term or not. Any ideas on how to work this out? I honestly can’t find any boards better than these at the box stores.
-- Verily, verily, I say unto you, He that heareth my word, and believeth on him that sent me, hath everlasting life, and shall not come into condemnation; but is passed from death unto life. ~ John 5:24
16 replies so far
View Scot's profile
Scot
344 posts in 3271 days
#1 posted 02-05-2012 05:55 AM
Can’t get them straight with a Jointer?
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
Matt Stauffer
#2 posted 02-05-2012 06:48 AM
Finally got a photo up. The edges of the planks are jointed, but the boards do not want to lay flat. I bought the wood over a year ago and it has had more than enough time to “settle” out. In my picture you can see the misalignment that I’m concerned about. Hoping that using some oak dowels along the jointed edge will help the top to stay flattish.
View Scot's profile
Scot
#3 posted 02-05-2012 06:52 AM
Do you have a jointer wide enough to face joint the boards?
Matt Stauffer
#4 posted 02-05-2012 07:53 AM
“Do you have a jointer wide enough to face joint the boards?” – MoPower
Yes, but it takes too many green chile burritos to power it.
View Scot's profile
Scot
#5 posted 02-05-2012 08:11 AM
LOL. I guess dowels are probably your best answer, or another idea may be to try a tongue and groove joint using a router and rabbiting bit ?
Matt Stauffer
#6 posted 02-05-2012 08:36 AM
You probably guessed that my router looked something like this…
View Scot's profile
Scot
#7 posted 02-05-2012 08:40 AM
I’ve been sitting here thinking about the tongue and groove idea and I think that would be a good way to go. Looking at the pic of your boards, they are not bowed that sharp, so a small based router with a 1/2” ball bearing rabbiting bit should easily follow the contour of the board easily keeping everything centered while cutting both the tongue and grooves.
The only down side I see is that the width of the top will be decreased by the depth of the joint at each joint.
the up side is that it will be a strong joint and easier to assemble than dowels.
116813 posts in 3452 days
#8 posted 02-05-2012 08:46 AM
Did you buy kiln dried wood? If your woods dry enough your should be able to just glue them togehter let them dry and they will hold assuming you have enough clamps. You can glue one half of the bench top at a time and then glue the two halves together to make it easier. If you use dowels you will have problems aligning the dowels on bowed boards.
View Scot's profile
Scot
#9 posted 02-05-2012 08:48 AM
Well…I guess it’s either lots of burritos or lots of dowels ! Those burrito powered tools can sure put the weight on if your not careful.
Matt Stauffer
#10 posted 02-05-2012 09:21 AM
It’s getting late, so I guess I’ll save these for tommorow and try the burritos and dowel rods.
View wdworking's profile
wdworking
31 posts in 2276 days
#11 posted 02-05-2012 10:44 AM
I used SYP for my top but, I bought 2×10’s and cut them into 3 sections each. Turned them end on end to make the table at least 3” thick. I put the cut side down and after I glued them up, I turned the top over and that was my top. I have planed it on an angle to make it flat. I have less than $30 in the top. I have also drilled 3/4” dog holes into it. Looks good. It’s not soft maple like I would prefer, but it will do for now.
Hope this helps.
-- Craig http://www.wouldworking.com
View William's profile
William
9949 posts in 2717 days
#12 posted 02-05-2012 03:34 PM
I agree with Jim that if you can get them into line and glue them straight, they’ll hold each other straight. I suggest alternating any curve in the end grain, the way you would any kitchen table top or picnic table.
Also, the dowel point centers you show, if you can’t get them to lay in line to start with, those are going to be hell to get lined up right.
Another option that would be less of a pain to line up would be a biscuit jointer. As long as the bow isn’t sharp enough to interfere with the fence on a hand held biscuit jointer to set flat, You can mark and cut your slots for the biscuits at certain spots along the length. Then glue the board together using biscuits. Apply firm, but not overly tight pressure with clamps. Use a rubber mallet to know out any remaining (should be very tiny with biscuits in place) deviation between the boards. Then tighten the clamps on down and let dry.
wdworking
#13 posted 02-05-2012 11:16 PM
You can disregard my earlier post. I looked up a Nicholson style bench afterwards.
View jmpreiks's profile
jmpreiks
11 posts in 2198 days
#14 posted 02-06-2012 04:41 AM
Some cauls should help line those up during the glue up. You shouldn’t need any fancy joinery in my opinion.
Matt Stauffer
#15 posted 02-06-2012 05:08 AM
Good “caul”!
I got some work done today on the most laborious piece of the top. I cut all the dog holes with a sash saw and used a chisel to knock out the majority of the waste, and used my burrito powered router to get a clean bottom. Still have to clear a notch for the head of the dogs and custom fit each dog hole so that the dogs can fully hide if needed.
