Burnt Birch ?
Forum topic by SawdustMill posted 142 days ago 204 views 0 times favorited 7 replies Add to Favorites
View SawdustMill's profile
SawdustMill
41 posts in 221 days
142 days ago
Topic tags/keywords: question wood burnt birch
I went to my local lumber yard the other day, and they had a new kind of wood available they called Burnt Birch.
It’s a really deep chocolate color with nice grain patterns, and was at a really good price compared to walnut (which is what I was there for).
I came home to do some research on it, but haven’t been able to find anything. Do any of you have any experience with this wood ? Is there a different name I can use to research it ? Does it work well ? Does it take finish well ? Any samples of what a finished burnt birch project looks like ?
Thanks !
View GaryK's profile
GaryK
8489 posts in 478 days
142 days ago
You got me!
View John Ormsby's profile
John Ormsby
165 posts in 226 days
142 days ago
One of my lumber suppliers gave me a board about a year and a half ago. Have not yet tried to do anything with it. Don’t know anything about it. It looks like it is processed in some way. Might have to go out and mess with it.
-- Oldworld, Fair Oaks, Ca
View Dusty56's profile
Dusty56
1185 posts in 177 days
142 days ago
About a year ago , I was at a millwork supplier and he showed me a piece of “mystery wood” It was the Burnt Birch that you are referring to . If I remember correctly , he told me that it was actually cooked in an oven at high temperatures to remove all moisture from it and that made the Birch very stable for use as exterior mouldings , etc. , and that the “cooking” process somehow sealed all the pores in the wood making it rot resistant because it can no longer absorb moisture . Of course it smelled like it was burnt to me as well , but the dark , rich color was attractive. If I get a chance , I will try to contact him for more info for all of us to share : )
-- Dusty56@comcast.net
View relic's profile
relic
315 posts in 426 days
141 days ago
I have some that I used on a couple of small projects. I’m told its 4-6% dried 3 times long and much hotter than normal. This is what I found when working with this wood.
Where a mask, everything you do will produce small chips and lots of dust.
Every thing will smell like burnt wood.
Gluing has not been a problem.
Sanding is no problem.
The pieces I have seem to be a light green when the sun hits it. When I talked to my suppler more about this wood he told me that a couple of shops are using it for molding quite successfully.
I hope this helps.
-- Andy Stark
View Boardman's profile
Boardman
82 posts in 251 days
141 days ago
About 2 years ago I came across a site about “toasted hardwoods.” Can’t remember all the details, or find the site at a glance, but it showed several species that were “toasted” and were browner than plain kiln dried lumber. I do remeber the caveat to let it acclimate since it’s very dry after toasting. Guess it didn’t take off too well because this is the first time I’ve seen it mentioned since then.
Boardman
141 days ago
Here’s one link:
http://curiouswoods.com/wood--Roasted-Hardwood--RH
Apparently it comes from an outfit in Quebec, or maybe more place too.
SawdustMill
141 days ago
Thanks for the info all, super helpful !
Bookmark And Share This Page
