My Cheapy Home Made Router Lift
Forum topic by ohtimberwolf posted 02-04-2012 02:44 AM 8021 views 0 times favorited 8 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
777 posts in 2314 days
02-04-2012 02:44 AM
Topic tags/keywords: router lift router cheap home made
Well, here is my cheapy fix to raise and lower my router. I know it isn’t great but it works and I can fine tune it if I have to. I took one handle off so I could lift the insert and router out of the hole without a problem. Then I replaced the part that raises and lowers the router with a hex head bolt.
I took an old reversible drill I had laying around and built a holder for it to keep it stationary and in an upright position. I ran the cord through the box to a switched receptacle for power. To go up you push the button on the drill to the right and to the left to go down. The drill is holding a cut off extension with a deep socket that the hex head bolt, that raises or lowers the router, fits into to do the work. I just run the thing up to nearly where I want it and hand turn the socket to fine tune it if necessary. A switch could be rigged to run the drill forward or backwards from outside the box to make it even easier but I didn’t think it was worth the extra effort at this time. I wanted something NOW and it can be improved on later.
When you lift the router up out of the table the hex head bolt just lifts out of the deep socket and it goes back in when you return the router. If this helps someone else that is nice. If not, well I tried. larry
-- Just a barn cat, now gone to cat heaven.
8 replies so far
View Dallas's profile
Dallas
3599 posts in 2449 days
#1 posted 02-04-2012 02:54 AM
Cool Beans! Now I have to figure out how to build one that will work on my router!
117060 posts in 3539 days
#2 posted 02-04-2012 02:58 AM
Very creative idea. good job.
ohtimberwolf
#3 posted 02-04-2012 03:11 AM
Thanks guys, I was sort of afraid it might only draw criticism. For what it is worth, you make me feel better.
View RandyM68's profile
RandyM68
693 posts in 2280 days
#4 posted 02-04-2012 03:31 AM
That’s a good idea. You can pick up old drills for 10 or 15 bucks at the pawn shop. You actually just gave me an idea for driving a lead screw on a project of mine. That’s a lot faster than a ratchet. Marking the up and down is nice, too. I’d forget which was which. And don’t worry, they only make fun of you for your politics here.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
ohtimberwolf
#5 posted 02-04-2012 04:07 AM
Good idea Chipmunk, wish I had thought of that as I have one of those.
ohtimberwolf
#6 posted 02-04-2012 04:40 AM
IMPORTANT UPDATE!!! DANGER…DANGER…DANGER
BE SURE TO USE A VARIABLE SPEED DRILL FOR THIS RIG AND RUN IT SLOW.
View Danpaddles's profile
Danpaddles
573 posts in 2274 days
#7 posted 02-04-2012 04:46 AM
I like that.
Wonder if I could do that for my drill press table.
-- Dan V. in Indy
ohtimberwolf
#8 posted 02-05-2012 11:47 PM
Hey guys, be sure to post your impovements and pictures when your done. Please put in the tags Home Made so we can find them as they progress. I love to see the new ideas. larry
