| Forum topic by RBWoodworker | posted 470 days ago | 767 views | 1 time favorited | 12 replies | ![]() |
470 days ago |
I am currently moving my shop which is and hour and 20 minutes away from where I live to where I am living now.. the landlord has a huge structure that he said I could use no charge..anyways.. my question is.. for my tablesaw, which I have a powermatic 66 5 hp that draws 26 amps.. the landlord has an outlet for his motorhome that he’s not using but its hooked up to a 50 amp breaker..my question is..will a 50 amp outlet harm the lower amperage machines? the cords on the machines are all very heavy duty with #6 wires but I’m concerned about the motors having that much amperage going into them.. -- Randall Child http://www.racfurniture.com/ |
12 replies so far
#1 posted 470 days ago |
The saw will only draw the amperage it needs. The 50A outlet will not “push” 50A into your saw. Just make sure voltage is the same….. RVs don’t usually run on 220v. 5HP table saws … do. -- -- Neil |
#2 posted 470 days ago |
A 50 amp circuit breaker doesn’t mean that the circuit actually carries 50 amps – it’s just protected to that level. -- Adversity doesn't build character...................it reveals it. |
#3 posted 470 days ago |
thanks guys..I was concerned.. but that helps alot..I’m good to go then.. -- Randall Child http://www.racfurniture.com/ |
#4 posted 470 days ago |
You’re in good shape. Nice to have a fat line like that. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#5 posted 470 days ago |
Make sure the voltage is right your #6 wire is good for the amperage should be ok -- Russel C |
#6 posted 470 days ago |
Along with what everyone else said… as long as your saw has a built in breaker to protect itself from a stall condition, you will be fine. -- Perilous to all of us are the devices of an art deeper than we ourselves possess. --Gandalf the Grey http://davidwahl.org/category/woodworking/ |
#7 posted 470 days ago |
Hey Randy -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#8 posted 470 days ago |
Or what Jim said, seems like he had the same thought I did :) -- Perilous to all of us are the devices of an art deeper than we ourselves possess. --Gandalf the Grey http://davidwahl.org/category/woodworking/ |
#9 posted 470 days ago |
Ok.. this is what I found.. I checked in my panel and I have a 2 wire 40 amp empty breaker.. which is perfect for my 220 needs.. and 3-20 amp breakers which is perfect for all the rest.. it looks like I’m good to go now guys.. thanks.. -- Randall Child http://www.racfurniture.com/ |
#10 posted 469 days ago |
Size your breaker so that the equipment does not draw more than 80 percent of its rating, or looking at it the other way, do not up size the breaker more than 20 percent of the equipment draw. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#11 posted 469 days ago |
As was stated in the first post An RV 50a recepticle isn’t suitable for a 220 circuit. It is 2 120v circuits in one outlet. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
#12 posted 469 days ago |
I have not read the first post. Your saw needs a 220 Vac, single phase. The CB should be a 2-pole breaker. You should be using line to line (color code likely to be black & red). Unless the saw calls out for it, you shouldn’t need a neutral (white wire). You will always use the ground wire (green or bare). You will need to consider the motor starting in-rush current. A standard 30A circuit breaker will likely trip during starting of your saw due to motor inrush current. Get a CB that is rated for the motor load. Another words, a CB with a HP rating that matches your saw. This is the simplest approach. Since motor starting current is relatively short, you want a CB that could “Ride” throught that period of time and not trip. Whatever this “HP” rated CB’s amp rating is, your wire size shoudld match the CB size (assuming the circuit length is within reason). The CB not only protects the load. It also protects the wire. I think this is the safest approach. Sizing a standard CB could be challenging and complicated. CB comes in differnet flavors (Ex: fast, normal, slow, very slow). To prove that your particular CB is adequate or not, you will need to know the exact Manufacturer, model of the CB; obtain the CB & motor trip current curves…...........................................No one is really interested in this. It doesn’t generate wood dust. Well, it might burn some. -- I'll be a woodworker when I grow up. HHHOPKS |
| Forum | Topics |
Woodworking Skill Share
8783 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
