Lock Miter joint
Forum topic by daveintexas posted 96 days ago 614 views 0 times favorited 8 replies Add to Favorites
View daveintexas's profile
daveintexas
172 posts in 317 days
96 days ago
Topic tags/keywords: lock miter legs router splines
Disregarding using a lock miter router bit, does anyone have a technique for making this joint?
I would like to make some 3” square legs using 3/4” thick material. I have not had much luck ripping 45 degrees and then trying to get the angles to stay in place during glue up.
Would splines work in this case?
Thanks
Dave
-- MISSION FURNITURE-My mission is to build furniture
View tenontim's profile
tenontim
823 posts in 186 days
96 days ago
Splines would work. Also, you can cut most of the waste on your table saw, then use a 45 degree router bit to finish of the angle. Cut your miters and you’re set. I use the plastic wrap for packaging to “clamp” my square pieces.
-- Tim -- http://tmuli.com
View motthunter's profile (online now)
motthunter
1154 posts in 240 days
96 days ago
buying aset of lock miter bits can help also. They are a trick to set up, but once you have it… you are good to go
-- making sawdust....
View Betsy's profile
Betsy
1760 posts in 337 days
95 days ago
Dave – I’m with Tenontim. The package tape works great. Tape the outsides and roll it into a box and away you go. Little to no slipping with this method. And once taped, if you still want to clamp it for extra pressure you can.
-- Betsy - GO BUCKS!
View jcees's profile
jcees
438 posts in 241 days
95 days ago
I’ve used splines, biscuits and lock mitres. They all work. Lock miters have a spline built in and are really meant for long grain thus they’re perfect for making strong legs. Buy a high quality bit, you won’t be disappointed. Work up some test pieces and once you have the settings MAKE A SETUP GAUGE out of your test pieces. This will make it a cinch to setup the next time. And if you have more money than time, you can buy setup gauges for the lock miter bit here…
http://eagleamerica.com/kwik-block-sets--lock-miter/p/486-1921/
Good luck.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View stanley2's profile
stanley2
175 posts in 237 days
95 days ago
Don’t know why you don’t want to use a lock mitre but but to each his own. Without one I would set my saw at just a tad over 45 degrees (45.1) to avoid an opening on the outside of the joint. I would use splines. I would also oversize the width of the board and run the leg thru the drum sander when glued up to final size. The result should be closed tight joints. But the lock mitre bit looks after all the precautions needed otherwise.
-- Phil in British Columbia
tenontim
95 days ago
Dave, I forgot to add, if you use the lock miter bit, set your fence on your router table to take the wood away a little at a time. If you try it all at one, especially with hard wood, it’s going to tear out all over the place.
View rikkor's profile
rikkor
7093 posts in 316 days
95 days ago
Here’s an instructional video on the miter lock system.
-- Maplewood, MN
2579 posts in 421 days
94 days ago
Hi Dave;
I posted a blog; http://lumberjocks.com/jocks/LeeJ/blog/4775
which I hope will help with your question.
Bookmark And Share This Page
