| Forum topic by MrRon | posted 474 days ago | 1145 views | 0 times favorited | 15 replies | ![]() |
474 days ago |
I’m wondering if it is OK to joint the edge of plywood or will it damage the knives? |
15 replies so far
#1 posted 474 days ago |
I read an article not too long ago that didn’t recommend it: |
#2 posted 474 days ago |
Rule of thumb is, if it’s man made, no. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#3 posted 474 days ago |
Glue will dull the knives rapidly but just a now and then deal youll be ok. Even frequent use would be ok if neccessary. Just need more frequent sharpening and setup but that is easy enough. Have at it |
#4 posted 474 days ago |
dear MrRon
planing ply is more than except-able on a jointer and you can achieve a good finish…But it is best to only use one side of the blade…if you keep the section nearest the guard/furthest away from you just for man made boards…leaving the rest of the blade for premium quality for hard/soft wood….this way only a small piece is worn.. -- jjempson |
#5 posted 474 days ago |
Thanks for the replies and answering my question. |
#6 posted 474 days ago |
MrRon: I have jointed plywood before several times, and it can be done….didn’t hurt my blades any….I haven ‘t did a lot, but I have did it…..go for it….. -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#7 posted 474 days ago |
Here’s a TIP if you decide to joint the plywood. Make a releif cut on the heal of the board first so the cross grain plys don’t tear out when you make the full pass. Just like jjempson, I use the far edge of my blade for riskier cuts, then move my fence forward for the cleaner stuff. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#8 posted 474 days ago |
Yeah. I’ve both jointed AND planed ply, but I try not to make a habit of it. I think it’s put together with epoxy, and THAT’s the big issue. Hard on blades. -- -- Neil |
#9 posted 474 days ago |
get that cnc built and use it for jointing. these machines work great for this I dont use my jointer anymore for 90deg only if I have to bevel. -- nelson woodcrafters |
#10 posted 474 days ago |
I too have done it before, not much of a cut but I don’t see any problems with it. -- Don, Royersford, PA |
#11 posted 474 days ago |
Yes , I’ve jointed the edges safely as well. Not a lot , but more than once : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#12 posted 474 days ago |
Yes it can be done. The glue WILL dull the blade quickly, as a few other suggested ,use one edge of jointer knife only. Now a days I have a special 4” jointer for this purpose….....plywood (glues), painted boards (paint is also hard on blades), edges of panels with formica, I do a lot with reclaimed lumber so this little jointer takes the beating leaving my bigger jointer for serious solid woods only..! -- "My mission in life - make everyone smile !" |
#13 posted 473 days ago |
Thanks for all the great tips. I don’t need to joint plywood often, just to take the fuzziness off the edge. DS251: Taking a relief cut off the heel is a good idea. |
#14 posted 473 days ago |
OK to do by me. Have to be careful because of chip out. Blades were made to dull when you use them. I’m a philosopher. -- Phil Zoeller louisville, KY |
#15 posted 473 days ago |
The way to do it is use only the 1” closest to the pulley on the |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15763 |
Hand Tools
2034 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
