Blade tension setting on Jet 14 inch bandsaw
Forum topic by Ralph610 posted 02-01-2012 05:27 PM 1966 views 0 times favorited 3 replies Add to Favorites Watch
View Ralph610's profile
Ralph610
22 posts in 2215 days
02-01-2012 05:27 PM
Folks
I’m never sure if I have the tension right on the blade when changing it . How is this done ?? Thanks
3 replies so far
View Bill White's profile
Bill White
4856 posts in 3866 days
#1 posted 02-01-2012 05:46 PM
Google bandsaw blade tensioning. There is a BUNCH of stuff there.
Bill
-- bill@magraphics.us
View syenefarmer's profile
syenefarmer
483 posts in 2986 days
#2 posted 02-01-2012 07:39 PM
I just tension mine until I only have ΒΌ” right to left movement of the blade.
View TheDane's profile
TheDane
5367 posts in 3569 days
#3 posted 02-01-2012 07:41 PM
Ralph—I have a Jet 14” that I retrofitted with a Carter Quick Release. With the Carter QR released, I change the blade, set the tension using the built-in indicator that came on the saw for the size blade I installed, then raise the lever on the Carter … it has always worked well (for some reason, my saw has never had any drift … cuts straight as a string).
On my old Craftsman, I would raise the guide all the way then set a square on the table about 1/4” away from the blade and press (moderate pressure) on the blade about midway between the table and guide with my index finger while tightening the tension. When it got tight enough that I could press only press the blade 1/4” I was good to go.
—Gerry
