Tablesaw Dust Shroud Retrofit
Forum topic by Tyrone D posted 02-01-2012 10:16 AM 2273 views 0 times favorited 1 reply Add to Favorites Watch
View Tyrone D's profile
Tyrone D
314 posts in 2241 days
02-01-2012 10:16 AM
Hello,
I just recently purchased a Wadkin Bursgreen AGS10 and am completely restoring it. One of the things I would like to do is add a dust shroud.
The saw is right-tilting, which shouldn’t make any difference.
I’m going to make it out of sheet metal. It will be mounted to the trunnion with two bolts and will have either a 2” or 4” opening depending on whether I can fit a 4” hose in the saw.
Has anyone ever done this and is willing to share advice?
Do you have any pictures of a dust shroud on your saw?
I’ve been on Google for quite a while and have found nothing.
Thanks.
-- --Tyrone - BC, Canada "Nothing is ever perfect, we just run out of time."
1 reply so far
View WorkTheWood's profile
WorkTheWood
35 posts in 2308 days
#1 posted 02-04-2012 10:39 PM
Check this out – may give you some ideas.
http://eaglelakewoodworking.com/post/Overarm-Dust-Collector.aspx
-- -- Lou Stagner
