| Forum topic by jmkeuning | posted 476 days ago | 1048 views | 0 times favorited | 2 replies | ![]() |
476 days ago |
I have read a number of conversations about upgraded miter gauges and how they will not fit saws with 5/8 miter slots. Has anyone swapped the bar for a narrow bar? Seems pretty straightforward. |
2 replies so far
#1 posted 476 days ago |
If the width was the only problem it would be pretty straightforward. But most “cheap saw” miter slots have these little protursions sticking out that ride above the bar to keep it in the track. To make it worse, they are not full length, but just stick out in a couple of places. Not impossible to work around, but a pain in the ars. They are not limited to “cheap saws” either. Almost every benchtop and portable saw sold by Sears, Ryobi, and a lot of no-name saws have this feature. Its the simplest way to get miter bar retainage on a die cast aluminum or stamped steel saw top. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#2 posted 476 days ago |
years ago I had a cheap saw with exactly that issue and I tried to get past it as you suggested by replacing the 3/4 bar on one of the accessories with 5/8 bar for one of the cheap items. Unfortunately, it didn’t work because most of the 5/8 bars don’t fit firmly enough in those tracks and the amount of play between the 5/8 track & bar defeats the advantage of using a precision gauge. -- Greg, Severn MD |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
