Question home made reamer
Forum topic by SuperDave02 posted 02-01-2012 01:21 AM 4083 views 1 time favorited 8 replies Add to Favorites Watch
View SuperDave02's profile
SuperDave02
141 posts in 3406 days
02-01-2012 01:21 AM
Topic tags/keywords: question
I made this reamer to eventually make some rounder planes. Problem is it gets clogged up with only a turn or two. Is this Normal? What if there was a few groves cut lengthwise to act like gutters to hold the sawdust? Maybe I could get a few more turns before needing to clean out the sawdust. Thanks
-- David South FLorida http://rockingrrustics.blogspot.com/
8 replies so far
404 - Not Found
2544 posts in 3144 days
#1 posted 02-01-2012 03:38 AM
I’m not sure that I can offer the best advice on this, but would a down shear action help to clear the waste? i.e. if the blade was at an angle.
View Don Johnson's profile
Don Johnson
698 posts in 2955 days
#2 posted 02-01-2012 12:49 PM
Metal reamers only take off minute amounts of material so their swarf grooves are fairly small – but they are there.
Is your wood reamer acting more like a drill in terms of material removed ? – in which case I guess it WILL need grooves to accommodate the scrapings.
-- Don, Somerset UK, http://www.donjohnson24.co.uk
View Bill White's profile
Bill White
5105 posts in 4135 days
#3 posted 02-01-2012 06:59 PM
Reaming is one job. Drilling is another. Your shop-made reamer should be used to dress rough holes, and looks to be well made (love the handle). The alternative would be a bung borer. It is a hand tool. Take your time and enjoy the quiet.
Bill
-- bill@magraphics.us
View Bertha's profile
Bertha
13550 posts in 2868 days
#4 posted 02-01-2012 07:25 PM
It seems like there’d be a way to elevator the chips out but I’m not the one to figure it out. I would think a gutter acting as an escapement of sorts might help. I’m not smart enough to design an angled blade but if it was hollow with a communicating gutter, the chips might fall from the center. Nice tool.
View MrRon's profile
MrRon
5139 posts in 3418 days
#5 posted 02-02-2012 12:35 AM
I would think a bit more steel exposed on the leading edge whould provide more clearance for chips and sawdust.
117276 posts in 3752 days
#6 posted 02-02-2012 01:57 AM
Here’s a Link to Curtis’s reamer
http://www.greenwoodworking.com/SawSteelTaperedReamerPlans
View David's profile
David
10 posts in 3961 days
#7 posted 02-14-2012 05:33 PM
http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=33934
The link is to a short video by Peter Galbert on how to ream Windsor chair mortises. The video does an excellent job of describing the proper use of the reamer and how to clear during use.
David
View mafe's profile
mafe
11741 posts in 3264 days
#8 posted 02-08-2015 11:14 PM
http://lumberjocks.com/mafe/blog/28109
