| Forum topic by johnintecumseh | posted 478 days ago | 554 views | 0 times favorited | 8 replies | ![]() |
478 days ago |
Hey guys here is a good question for all. I have 3/8×16 inserts from HD. the outside thread is 11/16 and the groove between threads is 5/8. A5/8 hole will not let the insert in. If I drill 11/16 will the thread ‘bite’ Is there a standard way to use these inserts I want to put them in end grain and turn beer tap handles. your help is appreciated. Keep smiling John -- retired and smiling |
8 replies so far
#1 posted 478 days ago |
Try 41/64” for soft wood or 21/32” for hard. Use the 11/16” to bearly break the surfice of the piece, maybe 1/64”. Then driill the center with the smaller bit. The 11/16” entry will help keep the insert centered, until the threads begin to bite. Most of the threaded inserts are not intended for endgrain. Adding a little was to lubricate the outer threads will help. -- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim |
#2 posted 478 days ago |
I presume that you’re talkin’ about threaded (brass) inserts. Gotta get the correct tap and drill for the insert. Look at a thread chart. 3/8” x 16 takes a 5/16” bit and the appropriate tap. You’ll need a blind hole tap, not a “thru” hole tap. You can get a standard tap and grind off the end for bottoming holes if that is what you’re after. -- bill@magraphics.us |
#3 posted 478 days ago |
If the OD of the insert is .375 (3/8”), then the insert is meant for a 1/4-20 bolt. The drill size should be 11/32”, not 11/16”. |
#4 posted 478 days ago |
The inserts I’ve used for bed frames come with a Hex head before the start of the thread for insertion with an allen key. If yours are the same, I managed to get mine in square by first drilling a hole on the PD in a piece of scrap, winding the insert in – 1/2 turn forward, 1/3 turn back, when the insert bottomed out of the scrap, put that piece over the hole in the workpiece and repeat the winding in like you’re cutting a die. The scrap will keep the insert square as long as it’s firmly held against the hole the insert is going into. -- Do or do not, there is no try |
#5 posted 477 days ago |
Hey guys. I just got a reply from Lee Valley . they have a Propell nut 00n2302 needs a 29/64 hole and epoxy. this should make it a lot easier. Thanks to all who replied. keep smiling John -- retired and smiling |
#6 posted 477 days ago |
This is the way to install threaded inserts. http://www.youtube.com/watch?v=tIhEqoKE8Dc&feature=player_embedded -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#7 posted 477 days ago |
Excellent video Jim, I’ll give that a try next time. -- Do or do not, there is no try |
#8 posted 476 days ago |
Thanks Jim, very good info. On the side bar there are videos from scrollsaw.com . This turner is fearless and excellent. keep smiling John -- retired and smiling |
| Forum | Topics |
Woodworking Skill Share
8795 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15801 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
