| Forum topic by bevins587 | posted 505 days ago | 1053 views | 0 times favorited | 8 replies | ![]() |
505 days ago |
I picked up a used Craftsman table saw that had a Biesemeyer fence already on it. I noticed that the part of the fench that creates the friction from the handle was bent and I’m not sure if that is causing the problem or not. The fence will lock down but if you bump it, it will move and I would assume that this shouldn’t be the case. From the picture, does anyone have any suggestions as to what is going on (I can take all the pictures you need, just let me know what you want to see)? Also when I go to lock the fence down, should the handle go all the way pointed towards the floor or stop about 3/4? Don’t let the paint chips confuse you as to how bent the piece is, because it isn’t bent as bad as the picture makes it looks, has more of a sligh curve. |
