does this thing suck or what
Forum topic by schloemoe posted 01-31-2012 02:55 AM 1224 views 0 times favorited 9 replies Add to Favorites Watch
View schloemoe's profile
schloemoe
709 posts in 2843 days
01-31-2012 02:55 AM
Just a quick question… I just receive a H.F. dust collector thru a smokin deal . Its set up with 4” colectors leaving the unit .I have about 60’ of ridged pvc pipe that is 3” will I damage the unit if i by reducers to 3” and use that to run my perimitor. Just need to now it would be a hole lot cheaper than having to buy pipe…...thanks for reading any advise will be appreciated…....................Schloemoe
9 replies so far
View jack1's profile
jack1
2099 posts in 3933 days
#1 posted 01-31-2012 03:02 AM
The 4” would work the best but, it’ll still work with the three ”. Give it a try. Shouldn’t hurt the unit any. I neck mine down to less than that for some tools…
404 - Not Found
2544 posts in 2875 days
#2 posted 01-31-2012 03:06 AM
Any way you could just put in a 4” run for the thicknesser? If you took a big pass on a wide pine plank you might clog it up. Everything else should be ok.
116906 posts in 3483 days
#3 posted 01-31-2012 03:35 AM
Rick I’ve been running all of my HF dust collectors with 3” pipe for years ,no problem .
View Jonathan's profile
Jonathan
2608 posts in 2956 days
#4 posted 01-31-2012 05:16 PM
I don’t think it’s enough to worry about, especially since you’re not running huge industrial machinery. It’s just not going to run as efficiently, although you should still be fine. You’re simply creating a bit of a pressure difference, similar to a car exhaust system, only reversed.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
Beginningwoodworker
13347 posts in 3578 days
#5 posted 01-31-2012 05:51 PM
I use 4’’ pipe on my dust collector with good results.
View Bertha's profile
Bertha
13506 posts in 2599 days
#6 posted 01-31-2012 06:05 PM
I think if the pipe is rigid, you’re in good shape. I run 4” flexible, so I’m probably not qualified to comment. I sure WANT to run perimeter pipe, though;)
View Rob Drown's profile
Rob Drown
785 posts in 3738 days
#7 posted 01-31-2012 07:12 PM
3” has a cross sectional area of 7.06 in sq , 4” has 12.56 sq of cross sectional area. 4” is a lot bigger and will have less pressure drop.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
View crank49's profile
crank49
4029 posts in 2876 days
#8 posted 02-01-2012 01:20 AM
You are going to connect a 3” line to each of the 4” connections on the fan inlet if I understand correctly?
If so, you will be fine. The fan inlet is actually a single 5” before they stuck the 4” wye on there at the factory.
Two 3” pipes will have a cross section equal to about 72% of the true fan inlet.
If you have a problem with something making too many chips and plugging the 3” line you can always put one of those trashcan separators at the source with a short length of 4” hose connected to the machine. Then the 3” pipe will only be conveying mostly air.
View doordude's profile
doordude
1085 posts in 2888 days
#9 posted 02-01-2012 05:48 AM
schlomoe, it helps to get your answers right here.since you’ve got the 3” material already, a1jim says it’s ok then it’s ok. go for it
