how to make bridle joints on interior doors?
Forum topic by mrpedal posted 476 days ago 573 views 0 times favorited 4 replies Add to Favorites Watch
View mrpedal's profile
mrpedal
28 posts in 706 days
476 days ago
Topic tags/keywords: bridle joint interior door question
So I’m thinking of making some single panel interior doors for some closets and such, and was considering bridle joints. They are easy enough to make on a table saw with a jig… until I thought of trying to slot the 70+ inch long stiles. The rails are short 20”-30”, that’s prob still doable on the jig with some good clam-age, but… how does one normally go about doing this? Plunge router it out with a long bit?
87120 posts in 1745 days
#1 posted 476 days ago
Do you want to make bridle joints or mortise and tenon joinery? Normally you would use M&T and mortise the stile. The mortise can be made with a plunge router and long bit or drilled out and cleaned up with chisels.
View HalDougherty's profile
HalDougherty
1820 posts in 1405 days
#2 posted 476 days ago
a1jim is right. Normally you want to use deep tenons on a door. But, I made a shop door a few weeks ago using rails and stiles from 3/4” poplar. I made two frames using 4” wide boards. 2 long stiles and three shorter rails. One frame had the joint on the side and the other frame had the joint on the top so when both were glued into a 1 1/2” door, they weren’t at the same location. While the frames were drying, I cut 3/4” boards 4” wide and cut a rabbit on each side of them as well as the ends of the board. They fit into a rabbit I cut in the opening of the door. I stacked them in both openings and put glue on the frames. The interior panels are floating inside the frame. Then I glued and clamped them together. After the glue cured, I planed the edge to the size of the door opening in my shop and mounted hinges and the door handle and lock plate. I cut everything quickly with a hand held circle saw. If I had known how good the door would look, I would have used a sled on my table saw. I need a utility door for a rental house so I’m going to build a nicer one out of red oak, with the panels cut in a herringbone pattern.
-- Hal, Tennessee http://www.first285.com
mrpedal
#3 posted 476 days ago
The bridle ones appeared easier, and I dig the look. Also stops me from chiseling aka destroying work. Sorry, I am new to all this. Keep the comments comming.
View gfadvm's profile
gfadvm
6625 posts in 858 days
#4 posted 476 days ago
Half lap joints have many of the advantages of bridle joints but are easier to make on long stock using the table saw.
