Tablesaw blade intermitent vibration. Any thoughts?
Forum topic by Cam posted 01-30-2012 05:30 AM 2612 views 0 times favorited 6 replies Add to Favorites Watch
View Cam's profile
Cam
20 posts in 3346 days
01-30-2012 05:30 AM
Topic tags/keywords: tablesaw forrest blade vibration question
I have a contractors tablesaw with a newly installed Forrest woodworker 2 blade. I haven’t used it much, but when cutting any material, from hardwood to ply, the blade will vibrate for roughly 1 second every 3 to 10 seconds. When it vibrates, the blade spreads about a 1/64 up to a 1/32, widening the kerf.. I’ve never had this problem before. Would a blad stabilizer take care of this? Anyone ever dealt with this?
View Bobsboxes's profile
Bobsboxes
1362 posts in 2632 days
#1 posted 01-30-2012 05:56 AM
If it is full 1/8” kerf, that is what I run, I would check fit on shaft, runout on trunion bearings, clean washers. I can stand a nickle on edge while saw is running, mine is also a contractor saw. also check belt for flat spots. I have 2 of those blades and both run super and cut great. If your old ran true, I guess it could be blade. Good luck.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View ajosephg's profile
ajosephg
1880 posts in 3529 days
#2 posted 01-30-2012 12:16 PM
Does it only do it with the new Forrest blade? If so, that’s your problem.
If it does it with all your blades, it sounds like you have two different vibrations with slightly different frequencies. That causes a beat frequency with a period as you described. Since the only two things that rotate are the motor and arbor, I’d look there. Things like bearings, pulleys, shaft run out and belt.
I also have a contractor saw that had a similar problem (not as bad as your’s, because mine didn’t affect the cut), but I solved it by changing to a link belt. It now passes the nickle test.
-- Joe
View knotscott's profile
knotscott
7982 posts in 3344 days
#3 posted 01-30-2012 03:38 PM
Has the blade always done this? If it’s new, and does it only with this blade, I’d send it back.
View Bill White's profile
Bill White
4907 posts in 3929 days
#4 posted 01-30-2012 04:54 PM
You are seeing the results of harmonics being set up in/on the saw. Try another blade with different tooth configuration. If it repeats on another blade, ya might want to start looking at bearings as well.
Bill
-- bill@magraphics.us
View BobM001's profile
BobM001
388 posts in 2299 days
#5 posted 01-30-2012 05:23 PM
If you can get your hands on a dial indicator and a magnetic base check that blade for wobble at the highest point on its diameter you can. Also check your motor/arbor sheave alignment. If you detect any vibration or harmonics just running a bare arbor there are issues other than the blade.
-- OK, who's the wise guy that shrunk the plywood?
View jeter's profile
jeter
20 posts in 2556 days
#6 posted 01-30-2012 07:01 PM
I had the same saw for many years and used Forrest ww II blades on my saw too. I had a similar problem and I found it to be that the pulleys were slightly off and loose. The belt might be too tight as well. There are two screws with two bars where the motor hangs. Loosen the two screws and push in about ¼” or 3/8” of an inches in and retighten. Check the pulley as well.
Jeter
